CTR Cams
Old Mar 11, 2005 | 10:00 PM
BLK99VTECR's Avatar
Default CTR Cams
Does anyone who who sells CTR cams for the best availible price?
Old Mar 12, 2005 | 02:55 PM
BLK99VTECR's Avatar
Default Re: CTR Cams (BLK99VTECR)
Old Mar 12, 2005 | 03:47 PM
IggyBcool's Avatar
correct me if im wrong, but arent the ctr pistons pretty much the same as the ITR's?
Old Mar 12, 2005 | 04:44 PM
trellix78's Avatar
New User
Default Re: (99LStegra)
2001+ ITR intake cams are same as CTR.
Old Mar 13, 2005 | 06:18 PM
BLK99VTECR's Avatar
Default Re: (trellix78)
so who sells them for good prices
Old Mar 13, 2005 | 06:21 PM
IggyBcool's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99LStegra &raquo;</TD></TR><TR><TD CLASS="quote">correct me if im wrong, but arent the ctr pistons pretty much the same as the ITR's?</TD></TR></TABLE>
i totally ment cams guys...i promice
Old Mar 13, 2005 | 07:45 PM
00s2KkId's Avatar
check city-speed.com...brand new and pretty cheap
Old Mar 13, 2005 | 07:46 PM
00s2KkId's Avatar
lol already posted
Old Mar 14, 2005 | 12:46 PM
BLK99VTECR's Avatar
Default Re: (96GSRkId)
they got good deals on the cams in pair but I just need the intake cam, oh well if i dont find just the intake cam i will buy both.
is there much or a difference between the GSR exhuast cam and CTR exhuast cam?
Old Mar 14, 2005 | 10:08 PM
00s2KkId's Avatar
yes
Old Mar 15, 2005 | 12:39 AM
eg6sir-s's Avatar
http://www.icbmotorsport.com
Old Mar 15, 2005 | 05:33 AM
B18cya00's Avatar
Default Re: (eg6sir-s)
http://www.jdmuniverse.com/for....html Go their its a big debate on CTR vs. ITR cams, but it really depends on if u want a nice quick daily driver or a high idling race car... They tell you to go with the stage 1-3 cams because their not much more, but once u do that obviously you either need hondata or tune ur fuel with something else and your valve train needs to be upgraded.... TOO MUCH MONEY go with the ITR cams!!!
Old Mar 15, 2005 | 01:58 PM
BLK99VTECR's Avatar
i didnt see CTR cams anywhere on that site
Old Mar 15, 2005 | 10:52 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: (BLK99VTECR)
Too much money??? Bla thats just being cheap, spend the money and buy some bigger cams than type R's. FInd a good valvetrain setup, and a chipped ECU thall be a fantastic power increase
Old Mar 16, 2005 | 10:15 PM
00s2KkId's Avatar
if your looking just for a little power get the type r cams.... you can use your stock valvetrain but you wont be able to rev higher like some believe. just keep your rev limit at stock and you will be good to go
Old Mar 17, 2005 | 12:01 AM
obd2gsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96GSRkId &raquo;</TD></TR><TR><TD CLASS="quote">if your looking just for a little power get the type r cams.... you can use your stock valvetrain but you wont be able to rev higher like some believe. just keep your rev limit at stock and you will be good to go</TD></TR></TABLE>
um. ctr/itr cams are known to peak @ around 8300 on stock itr ecu fuel maps/rev limits.
if u were redlining @ 8K like the stock gsr, u'd be cheating yourself out of a few extra HP, which, in the end, could make or break a race.
if i were you, i'd get ctr cams and some good headwork. u'd be shocked how far those cams can take you, all while being 100% reliable. remember, no aftermarket camshaft is as strong as oem. NONE. PERIOD.
think about that... then make your decision.
Old Mar 17, 2005 | 09:16 AM
trellix78's Avatar
New User
Default Re: (obd2gsr)
The type R cams are not a bad deal.
I have 2001 ITR cams and some used valve springs that came with them in my GSR,
plus I ported and polished the head myself using a variable speed 1/4" chuck grinder
that I got off Ebay and a head porting kit from Standard Abrasives (very cheap).
I also polished and port matched the Blox intake manfold with the same abrasives kit.
That's a cheap upgrade, especially since I was replacing the head gasket, and it
pulls like mad right up to 8100rpms, even with the GSR ECU.
I plan on going OBD-1 with a chipped computer to gain some tuning advantages.
I don't know why people are saying the type R has no torque down low.
It feels like I have more torque even at 2000 rpms (might be explained by the Blox IM).
mugenDA9 lover
Mar 1, 2007 03:39 PM
allstockb18c
Aug 3, 2005 04:39 PM
CRX_GUY_123
13
Mar 28, 2004 06:54 PM
Wazup
16
Oct 29, 2003 11:13 PM
madhatch
Jun 23, 2003 10:37 AM
