bottom end build question
Old Mar 11, 2005 | 05:48 PM
kevslive95's Avatar
Default bottom end build question
my stampings on the block are CBBBB(54321)main caps and on the crank its 22221(54321). The guy at acura gave me 5 blue bearings for the block side of the crank journal and 5 yellow bearings for the main cap side it doesn't seem right and when i torque everything down the crank won't spin at all. i need green bearings to replace all the blue bearing right?????????? According to the markings right???????????? someone help!!!!!!!!!!
Old Mar 11, 2005 | 05:56 PM
98lsskunk's Avatar
Default Re: bottom end build question (kevslive95)
what you need are silicone injected acl bearnings if you are reving your motor high so you dont spin a bearing, if its a stock rebuild oe bearings will be fine.
more3688
Mar 30, 2010 03:14 AM
hYbRid_Eg6
Jan 19, 2010 10:03 PM
SuckMyDOHC
Jun 15, 2008 11:29 AM
scratchy
Mar 17, 2004 02:49 PM
