Clutch Issues..........................
Old Sep 28, 2005 | 06:23 PM
TheBobFather's Avatar
Default Clutch Issues..........................
Somethings up with this clutch of my gf car. !st it would grind gears and hesitate a lil espesially in 1st. So i replaced the slave. Drove it around for a week and then i couldnt get the thing in gear at all. The pedal feels fine. Any suggestions?
Old Sep 28, 2005 | 06:58 PM
Default Re: Clutch Issues.......................... (jnbhonda)
bump help
Old Sep 28, 2005 | 07:19 PM
thelate1's Avatar
have you checked the MTF level? could it use a change maybe? also, when it's hard to select gears it could be the syncros, or even the clutch release bearing.
fellow PA member bump........
hth........
Old Sep 28, 2005 | 07:59 PM
Default Re: Clutch Issues.......................... (thelate1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thelate1 &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the MTF level? could it use a change maybe? also, when it's hard to select gears it could be the syncros, or even the clutch release bearing.
hth........ </TD></TR></TABLE>
Thanks big!! Any other suggestions
Old Sep 28, 2005 | 08:34 PM
1 more bump for tonite
Old Sep 28, 2005 | 11:31 PM
dynamyks's Avatar
...sounds like your clutch is having trouble releasing...syptoms are very hard shifts and sometimes not going into gear...time for a new clutch
Old Sep 28, 2005 | 11:40 PM
bg-33p's Avatar
Default Re: Clutch Issues.......................... (dynamyks)
yup..sounds like ur clutch is gone..
Old Sep 29, 2005 | 12:15 AM
JDM_sedan's Avatar
its your shitty SOHC tranny
Old Sep 29, 2005 | 04:30 AM
Default Re: Clutch Issues.......................... (JDM_sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_sedan &raquo;</TD></TR><TR><TD CLASS="quote">its your shitty SOHC tranny </TD></TR></TABLE>
Nope it a 99 gsr
Old Sep 29, 2005 | 04:52 AM
JDM_sedan's Avatar
then its your shitty DOHC tranny
Old Sep 29, 2005 | 09:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_sedan &raquo;</TD></TR><TR><TD CLASS="quote">then its your shitty DOHC tranny</TD></TR></TABLE>
Nope, it aint shitty. Its a honda. Bad guess.
VTEC-LUDE
Nov 9, 2006 08:45 AM
TheBobFather
Jul 21, 2005 06:48 AM
jdmGSRcivic
Nov 19, 2004 12:19 PM
LonelyDriver02
14
Apr 1, 2004 01:32 PM
grngsr01
Jun 19, 2003 05:56 AM
