weird temperature problem
Old Sep 29, 2005 | 12:06 AM
Tripod's Avatar
Default weird temperature problem
i had my fuel injections cleaned yesterday and a new catbak exhaust installed today on my gsi....but i only noticed today that i had a really weird temperature readings...when i'm at a stop or near stop. the temperature goes up skywards...almost to the red line, but as soon as i start moving or accelerating the temp. reading drops immediately. (manual car)
any suggestions would be great...don't want to see the engine overheating
Old Sep 29, 2005 | 12:11 AM
JDM_sedan's Avatar
Default Re: weird temperature problem (Tripod)
GSI??
Old Sep 29, 2005 | 12:15 AM
Tripod's Avatar
Default Re: weird temperature problem (JDM_sedan)
erm. i'm in australia...that's the model :s
i think its the same as RS...not too sure...but yer...same thing all around. DC2
Old Sep 29, 2005 | 02:22 AM
JDM_sedan's Avatar
did you mess with the radiator or coolant? may have bled it wrong..... could you post pics of this aussie GSI? I don't think i've ever seen one before
Old Sep 29, 2005 | 03:01 AM
Tripod's Avatar
i just went out and tried to see what exactly triggers this temperature rise...
it looks like whenever my revs are under 1,000 that the temperature starts rise....and rise it does....
pictures? ... i only have old pictures of my car, havn't got any new ones... how do i attach images? ... i pressed add image and it came up with " [IMG][/IMG] "
Old Sep 29, 2005 | 03:05 AM
JDM_sedan's Avatar
you host it with something like we-todd-did-racing.com and then post the url between that IMG thing
Old Sep 29, 2005 | 03:07 AM
Tripod's Avatar
i'll do that later.
need to know what the hell is going ><
okaiz. these are 2 really old photos of my car. had a few things changed since then
Modified by Tripod at 6:18 PM 9/29/2005
Old Sep 29, 2005 | 05:13 AM
shamoo's Avatar
Will you make something up for me please?
Is your coolant level okay? Check your thermostat. Take it out and toss it in boiling water to see if it works. Or just remove the thermostat and drive the car. Does the water temp gauge stay lower and doesn't give you a problem anymore? If so, it's your thermostat.
Old Sep 29, 2005 | 02:29 PM
White cracker yeehaa's Avatar
yea, i have to agree w/ everyone on here, its most likely you radiator not being fully flushed, having air bubbles in there will cause that....thermostat gone bad too...try using some high performance additive in the coolant...
Old Sep 29, 2005 | 05:12 PM
Tripod's Avatar
Default Re: (DC2KinG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Is your coolant level okay? Check your thermostat. Take it out and toss it in boiling water to see if it works. Or just remove the thermostat and drive the car. Does the water temp gauge stay lower and doesn't give you a problem anymore? If so, it's your thermostat.</TD></TR></TABLE>
erm. to be honest. i don't know very much. eg. where the thermostat is or the water temp gauge. isn't the temp readings in the dash directly linked to the thermostat?
so do i need to add more stuff into the coolant? or buy a new thermostat? and if this problem prolongs, is it going to effect my engine adversely?
thanks
i just remembered something. when i got my injectors cleaned. they said my radiator hose is swollen. could it have anything to do with that?
i just opened up the radiator cap...there's nothing in there??? :s
and i have no idea how to take the thermostat out, i looked in my manual and i cant find it under the engine somewhere. and i'd have no idea which two hoses to touch
okaiz. i went to the dealer just then, it looks like a new thermostat is needed...sigh...that's another 200 bux down the drain &gt;&lt; GRRR...btw the pics are up
Modified by Tripod at 6:45 PM 9/29/2005
Modified by Tripod at 6:50 PM 9/29/2005
Modified by Tripod at 7:56 PM 9/29/2005
Old Sep 29, 2005 | 05:18 PM
kchungb17a's Avatar
Default Re: (Tripod)
First and foremost, make sure you have a full radiator. Make sure the engine is cold before you remove the cap, or you'll have hot scaulding coolant all over you!
Second: easy thermostat check: start the car and let it idle until it starts to get hot. Now touch the upper and lower hoses (be careful). If the upper hose is touchable, but the lower hose is so hot you can't put your hand around it, then the thermostat is bad.
Third: If both hoses are about the same temp to touch, and the thing is still getting hot, see if your fans are running. They probably aren't. If that's the case here are possible culprits: bad fan switch, or fan relay. Try turning on your AC and see if the fans come on. If they do, it's likely that the switch is bad.
Fourth: an RS is a DC4
Fifth: throw another shrimp on the barbie! (sorry had to throw that one in there!)
Old Sep 29, 2005 | 11:02 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tripod &raquo;</TD></TR><TR><TD CLASS="quote">i went to the dealer just then, it looks like a new thermostat is needed...sigh...that's another 200 bux down the drain &gt;&lt; GRRR...btw the pics are up</TD></TR></TABLE>
No! Stop right there! Don't pay $200 for the dealer to do your thermostat. It is VERY VERY easy. Look it up here on HT for instructions, or go to your local auto parts store and pick up a cheap Haynes/Chiltons manual and use that.
It should take you about 15 minutes (even if you know nothing about cars) just following the simple directions. The thermostat should cost you about $8. It's quite possibly easier than an oil change. Yeah, in fact I think it is.
EDIT: Here's a quick link to show you how. To make it easier, you don't even have to drain all your coolant, but you should to get all new fluid in there and make sure there are no bubbles in the system after you're done.
http://www.team-integra.net/se...D=222
Old Sep 30, 2005 | 05:32 AM
crx_88_si's Avatar
i agree, $200 is a little much.
also, instead of cracking the drain loose on the rad to drain it you could siphen out the fluid using a small tube and store it in a bottle and re-use if it's in good shape.
Old Sep 30, 2005 | 05:45 AM
Tripod's Avatar
Default Re: (crx_88_si)
thanks for all the help guys, $200...hmmph...out of my dads pockets hopefully ^^
i've already organised a time for the fix up with the dealer...don't really trust myself with a spanner and a screw driver
however, i'm looking buddy club body kit, does anyone know where i can get some pics? thanks
Old Sep 30, 2005 | 11:18 AM
98 Spec R's Avatar
Does your fan turn on?
Old Sep 30, 2005 | 05:45 PM
Tripod's Avatar
Default Re: weird temperature problem (98 Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R &raquo;</TD></TR><TR><TD CLASS="quote">Does your fan turn on?</TD></TR></TABLE>
nup. only the aircon fan
any pics??
Old Sep 30, 2005 | 08:29 PM
hondandy's Avatar
My car does this too, but only when low on coolant. Top it off and I bet it will be fine. If not try the steps these guys just recomended.
Old Sep 30, 2005 | 10:11 PM
98 Spec R's Avatar
If only the condensor fan turns on when your car is overheating that is not good. Both fans should be on. This might be part of your problem.
808tegg
Feb 23, 2015 05:25 AM
DC-2guy
May 4, 2009 05:09 PM
00 Civic EX
Aug 18, 2006 08:48 AM
nut R.
Feb 22, 2005 08:03 PM
