USDM ITR CLUSTER PROBLEM!!
Old Sep 29, 2005 | 09:46 AM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Default USDM ITR CLUSTER PROBLEM!!
i put a 1998 itr cluster from my 98 itr and i put it into my 94 gsr.everything works and is accurate but the gas guage doesnt work.its all the way down to empty,and i fill it up and still down so im not outta gas. i have the 98 itr harness, do i have to cut and splice it into the 94 obd1 harness bc the cluster is obd2? any help would be good!!
Old Sep 29, 2005 | 09:50 AM
_HANS's Avatar
Default Re: USDM ITR CLUSTER PROBLEM!! (honduhh)
and the cluster that was in the gsr ..the stock gsr cluster the fuel guage worked fine and the itr cluster when it was in the itr worked perfect as well..weird.i thought every teg cluster was plug and play!?
Old Sep 29, 2005 | 10:00 AM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honduhh &raquo;</TD></TR><TR><TD CLASS="quote">i put a 1998 itr cluster from my 98 itr and i put it into my 94 gsr.everything works and is accurate but the gas guage doesnt work.its all the way down to empty,and i fill it up and still down so im not outta gas. i have the 98 itr harness, do i have to cut and splice it into the 94 obd1 harness bc the cluster is obd2? any help would be good!!</TD></TR></TABLE>
the hell did you just say??? Did you mean you TOOK a 98 ITR cluster and put it into your 94??? If so....did you also take the green film from the back of the 94 guage cluster and swap it over to the 98 one before you plugged it in??? If nothing else....since everything works other than the gas guage....it could be that one gauge that's faulty. But try swapping that green film first.
Old Sep 29, 2005 | 10:09 AM
gsrious's Avatar
swap over the green thing and it will work just fine again.
Old Sep 29, 2005 | 10:23 AM
_HANS's Avatar
Default Re: (gsrious)
i dont have the green film .i sold the gsr cluster
Old Sep 29, 2005 | 12:30 PM
CNSK's Avatar
Default Re: (honduhh)
you need the green film...
Old Sep 29, 2005 | 11:02 PM
Naruto's Avatar
better go junkyard shopping then.....and hope you find one for cheap. Your only other alternatives are to go to ebay and pray you find one for a decent price or sell your arm, leg and left kidney to the black market and then go to the dealership
The reason why you need the green film off of your 94 cluster is because of how the wires are pinned into the plug end and wherever else it goes to. The 98 and up Integras are wired differently. You'll even get a hint of this when you compare a 98 and up gauge cluster to the 94-97s. The spots where ABS and stuff are located ( when they light up ) are in different spots.
Old Sep 29, 2005 | 11:56 PM
ricebox81's Avatar
becare though...the gas gauge is kinda finiky. I know a lot of people who when swaping out the cluster or installing indigo broke the gas gauge...mine is stuck on full -_-
Old Sep 30, 2005 | 11:29 AM
98 Spec R's Avatar
You dont need the green circuit board, you can repin the wires that are incorrect on the harness plugs. I have done this before and it works fine. There are 4 wires you need to swap if I remember correctly. Just use a pick tool and repin the wires.
Good Luck.
Old Sep 30, 2005 | 11:59 AM
HARI.'s Avatar
Default Re: USDM ITR CLUSTER PROBLEM!! (98 Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R &raquo;</TD></TR><TR><TD CLASS="quote">You dont need the green circuit board, you can repin the wires that are incorrect on the harness plugs. I have done this before and it works fine. There are 4 wires you need to swap if I remember correctly. Just use a pick tool and repin the wires.
Good Luck. </TD></TR></TABLE>
yup, it's really easy. the pin you have to re-wire is b3 which is the fuel gauge and put it on the b1 slot. hope that helps
Old Sep 30, 2005 | 01:42 PM
_HANS's Avatar
Default Re: USDM ITR CLUSTER PROBLEM!! (DA-HARI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-HARI &raquo;</TD></TR><TR><TD CLASS="quote">yup, it's really easy. the pin you have to re-wire is b3 which is the fuel gauge and put it on the b1 slot. hope that helps </TD></TR></TABLE>
more info please!! PICS!
Old Sep 30, 2005 | 02:42 PM
HARI.'s Avatar
ok, there's 2 plugs. the one with the 16 pin connector is called "B" plug and the one with 13 pin connector is called a "D" plug. on the "B" plug, locate pin connector #3 and take that out using a small screwdriver(i used the screwdriver to repair reading glasses to take the pins out).
once you have taken out "B3" pin, you will then have to put in slot "B1". you are re-pinning this because on your usdm gsr cluster, the fuel gauge is on b3, and the itr cluster is on b1. hope that helps.
Old Sep 30, 2005 | 04:38 PM
japracer96's Avatar
yea man thats what i did. I didnt have to change the green film. Works just fine.
Old Oct 3, 2005 | 05:56 AM
_HANS's Avatar
Default Re: (japracer96)
pics? or colors of the wires.i dont wanna F it up lol
Shocka1998LX
Jun 7, 2013 08:11 PM
Bonez21
Feb 13, 2006 07:36 AM
White GSR '01
Apr 14, 2005 08:15 PM
cleofis
Sep 30, 2004 05:44 PM
metal-x
May 24, 2004 11:12 AM
