compression low...valves bent?
Old Sep 29, 2005 | 12:15 PM
. M i c h a e l's Avatar
dotmichael to you
Default compression low...valves bent?
a guy i know is trying to sell me his cousins 96 ls. he said that its 100% stock and 156,000 miles. he told me two valves are bent. he just ran a compression check and these are the numbers
180 130 170 180
i figure a little carbon buildup so some seafoam would be nice..
i havent seen the car, and before i make the 2+ hour trip to look at it wanted to know what you guys thought. would a bent valve make the compression that low in a cylinder?
i've got the chance to pick it up very cheap..but i'm really not looking to do a ton of work to the head.
Old Sep 29, 2005 | 12:17 PM
JETSPD1477's Avatar
whats the selling price? small cylinder head job to replace a couple of valves and guides might be worth it. maybe replace all guides and rock a brand new used integra.
Old Sep 29, 2005 | 12:23 PM
dotmichael to you
Default Re: (JETSPD1477)
its got powdercoated fat fives and an oem itr spoiler, a swaybar and lowering springs, little stuff..
the cousin wants 2,500..but the guy i know.. (whos trying to help his cousin get the car sold and me into one) said i can probably get it for 1,800.
apparently there is a fat stack of records, with the most recent repairs being the timing belt, water pump, clutch, brakes all within the last 5,000 miles or so
Old Sep 29, 2005 | 12:40 PM
TrueUntilDeath.com's Avatar
Default Re: (. M i c h a e l)
maybe a shot piston or two, those numbers are pretty far apart.
mine is 210 200 200 190 on a 1998 ls w. 95k miles.
Old Sep 29, 2005 | 03:22 PM
dotmichael to you
Default Re: compression low...valves bent? (. M i c h a e l)
Old Sep 29, 2005 | 03:25 PM
kchungb17a's Avatar
A leak down test will tell you where it's leaking from!
Old Sep 29, 2005 | 03:27 PM
SingeBgd's Avatar
$1800 is really a good deal even with the bent valves and plus those mods are nice too IMO go for it
Old Sep 29, 2005 | 04:21 PM
Chewie's Avatar
Default Re: (Loveless.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loveless. &raquo;</TD></TR><TR><TD CLASS="quote">maybe a shot piston or two, those numbers are pretty far apart.
mine is 210 200 200 190 on a 1998 ls w. 95k miles.</TD></TR></TABLE>
those numbers are pretty high for b18b, got something bumping compression?
Old Sep 30, 2005 | 10:20 AM
Default Re: (Chewie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chewie &raquo;</TD></TR><TR><TD CLASS="quote">
those numbers are pretty high for b18b, got something bumping compression?</TD></TR></TABLE>
no, the motor gets taken care of.
Old Oct 1, 2005 | 05:58 AM
Cliffjumper2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l &raquo;</TD></TR><TR><TD CLASS="quote">
i've got the chance to pick it up very cheap..but i'm really not looking to do a ton of work to the head.</TD></TR></TABLE>
then you shouldn't pick this one up, nad if you do, might be easier and cheaper to just drop in another LS longblock.
dmonk87
Dec 3, 2011 05:27 AM
castanagajt
16
Oct 5, 2009 04:39 PM
B18C5_VTEC
Oct 8, 2007 02:54 PM
slowazzhatch
13
Jun 1, 2004 08:51 AM
