motor mount help
Old Sep 29, 2005 | 06:23 PM
turbob16ef's Avatar
From: if you build it they will come, the bottom carolina, duh
Default motor mount help
my question is if anyone knows if the motor mounts from an ef crx will fit into a DA. the crx had a b16 swap and got into a wreck and now i was wondering if those mounts fot in the DA body. they look about the same.
Old Sep 29, 2005 | 06:25 PM
turbob16ef's Avatar
Default Re: motor mount help (turbob16EF)
anyone ever try it
Old Sep 29, 2005 | 06:38 PM
turbob16ef's Avatar
come on DA owners someone has to know
Old Sep 29, 2005 | 08:29 PM
Dane Cook's Avatar
no they won't, completely different
Old Oct 1, 2005 | 06:09 AM
Cliffjumper2's Avatar
it's tricky to say with the information you provided.
since the guy had a b16 in his crx, he probably didn't have the stock mounts, then you would have to know which mounts did he use, back before they had mount kits, people use to use different assortment of mounts, and it's possible that one of them could fit your DA, but the only way to know is by trying....
but like I said it's hard to say, and the better answer is to assume they won't unless you try it out.
why not just pick up a set of used DA mounts/inserts/etc?
Old Oct 1, 2005 | 07:19 AM
R6E6I6D's Avatar
if he had a Bseries swap it will fit Just get old mounts... if it was a big block bseries ie:b20 its a no go... the driver side mount is a bit different in design... hope it works out for u
*****Stock mounts from d series are much different******
crazyboy
Jul 17, 2009 02:20 PM
CRX30436
Mar 17, 2008 03:23 PM
tallkan
May 6, 2007 11:28 AM
sickerhatch
Feb 28, 2006 06:27 PM
ht834
Nov 12, 2003 02:35 PM
