water pump
Old Mar 23, 2006 | 11:58 AM
Team AnWuT's Avatar
Default water pump
will a gsr water pump fit an ls motor
Old Mar 23, 2006 | 12:29 PM
BlueIntegraBoy's Avatar
Default Re: water pump (TeamAnWuT)
No
EDIT: It does fit
Modified by BlueIntegraBoy at 11:47 AM 3/23/2006
Old Mar 23, 2006 | 12:39 PM
WhoDoYouThink's Avatar
Default Re: water pump (BlueIntegraBoy)
I thought it would. Don't you use a vtec water pump when doing a LS/VTEC?
Old Mar 23, 2006 | 12:43 PM
Default Re: water pump (2000turbogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000turbogsr &raquo;</TD></TR><TR><TD CLASS="quote">I thought it would. Don't you use a vtec water pump when doing a LS/VTEC?</TD></TR></TABLE>
Oil Pump... now that I think about it the water pump can fit
Old Mar 23, 2006 | 12:44 PM
coo, thanx for the clarification.
Old Mar 23, 2006 | 04:47 PM
PandaBear's Avatar
Water pump and timing belt should be matching. If you use LS pump and LS belt on a GSR it will work, and vice versa.
Old Mar 23, 2006 | 05:37 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000turbogsr &raquo;</TD></TR><TR><TD CLASS="quote">I thought it would. Don't you use a vtec water pump when doing a LS/VTEC?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Oil Pump... now that I think about it the water pump can fit</TD></TR></TABLE>
you use both because the vtec water pump is designed for higher rpm operation....the gear is larger so the timing belt spin the water pump slower so the water doesnt aerate, the ls water pump would cause this because its spins faster.
as far as the oil pumps go the 96+ oil pump are the same but the previous year are different because they are design to supply different amounts of pressure.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaBear &raquo;</TD></TR><TR><TD CLASS="quote">Water pump and timing belt should be matching. If you use LS pump and LS belt on a GSR it will work, and vice versa.</TD></TR></TABLE>
what he said
Old Mar 23, 2006 | 07:10 PM
Sam92Teg's Avatar
Default Re: water pump (projectTeG)
If you have a earlier model LS, and you use a 96 or newer oil pump, you will need the newer lower timing cover to match.
Old Mar 23, 2006 | 07:23 PM
JDMB20TDA's Avatar
Default Re: water pump (Sam92Teg)
yea waterpumps can be changed
CivicVX94
Nov 27, 2006 05:45 PM
SpoolnG2
Mar 21, 2005 03:05 PM
MiKeAhOwSkI
Dec 30, 2004 04:02 AM
tegasaurus
Aug 10, 2003 01:07 PM
VWkila
Jan 29, 2003 02:09 PM
