Gauge Cluster dont work HELP PLEASE
Ok I just bought a 96 integra ls for $500 .thats the good part . ok heres my problem the gauge cluster does not work ,the light work in it but the gauges do not .i have checked all fueses and im stumped .has anyone had this problem ,and know how to fix it ? its not cool not knowing how fast im going or how much gas i got for that matter .any help is much needed thanks.
dont work at all? like they never move?
Pull the cluster out make sure the wires(plug) is pluged in... ALso chase the wires make sure no cuts in the line. If thats all good... Check around for another cluster... or if you have somone you know with the same car borrow there cluster to test it.
Re: Gauge Cluster dont work HELP PLEASE (bubbakrip)
i took the cluster out and looked at the wiring and no cuts and the plugs are fine ,took them out and pluged them in again .still not moving
Check the yellow wire to make sure there is power going in and I guess you could check your VSS on the trans and see if it's getting power and ground and putting out a signal. Also check the tach signal out on the distributor. Sounds like faulty cluster to me dog.
