Quick Noob Q.
Old Mar 23, 2006 | 08:16 PM
KArowd's Avatar
Default Quick Noob Q.
Searched on the forums for this, but pretty sure anyone could answer this: What does advancing your timing belt actually do? In depth detail would be gewd. thanks a lot. no flame, only the answer<3
Old Mar 24, 2006 | 03:50 AM
VTteg's Avatar
Default Re: Quick Noob Q. (DOughh)
I think you mean advancing the timing at the distributor. Cause advancing the timing belt doesnt make sense.
I havent done it before, but i beleive that the overall effect is to cause your motor to reach its peak horsepower earlier.
Also, make sure to search the archived content. I just did and found plenty of info on your topic.
Old Mar 24, 2006 | 06:41 AM
DC2SIR-G's Avatar
* B A N N E D *
Default Re: Quick Noob Q. (VTteg)
from my friends experience.. better throttle response
Old Mar 24, 2006 | 08:03 AM
T3mp3sT's Avatar
Literally, your causing combustion slightly sooner (advancing) which in turn can develop more power.
if advanced to far, you'l encounter other issues such as pre-detonation where essentially your motor is combusting so early that the power is totally lost (it attempts to push the piston back down to early).
Old Mar 24, 2006 | 06:17 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (T3mp3sT)
To expand slightly on the above post....
You are speaking of ignition timing. Ignition is the point when the spark is generated, causing the inigition (igniting) of the air/fuel mixture in the combustion chamber. From the factory, your timing is set at a certain point for best fuel economy and performance.
When you decide to alter it, you are changing the time at which the spark generates. This causes the air/fuel mixture to combust when the piston is at a different point of travel (before it gets to the top).
Old Mar 24, 2006 | 06:20 PM
Uncle Willie's Avatar
Default Re: (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">To expand slightly on the above post....
When you decide to alter it, you are changing the time at which the spark generates. This causes the air/fuel mixture to combust when the piston is at a different point of travel (before it gets to the top).</TD></TR></TABLE>
shamoo ALWAYS says it best. :beer
Chev
Jul 23, 2018 10:56 AM
corkss
Sep 13, 2008 09:51 AM
dogfood
10
Sep 25, 2004 12:31 PM
todaspecsi
10
Apr 20, 2004 12:03 PM
Riptide101
May 22, 2003 05:24 PM
