is it okay to put a jack stand a while?
Old Mar 25, 2006 | 09:10 PM
xkrntamax's Avatar
Default is it okay to put a jack stand a while?
I put jack stand on the passinger sit.(front and back)
Im little lazy to put my rims back.
or.... I have to go to sleep.
because im painting my rims.
So im thinking about to leave my jack stand all night.
is that okay? outside weather is about 37C
Old Mar 25, 2006 | 09:16 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: is it okay to put a jack stand a while? (xkrntamax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkrntamax &raquo;</TD></TR><TR><TD CLASS="quote">I put jack stand on the passinger sit.(front and back)
is that okay? outside weather is about 37C</TD></TR></TABLE>
Does the weather effect the jack stands ability to support the car?
As long as you have it in a good position you should be fine.
Old Mar 25, 2006 | 09:26 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: is it okay to put a jack stand a while? (Kind_of_a_big_deal)
^^ Yup, I left my front end on a jack over night when I was working on the fans/hoses ect..
Old Mar 25, 2006 | 09:31 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: is it okay to put a jack stand a while? (00IntegrAllmotoR)
Yes, it is perfectly fine to keep the car supported on jack stands for an extended period of time. In fact, many people store their car this way so they don't get flat spots on their tires.
I have had mine on jackstands (all 4 sides) for over 3 months when I was lazy doing my motor build/turbo install. Not to make fun of your English, but I saw your other thread wasn't too clear either. Are you using jack stands? Or are you using a jack to hold it up? A jack (hydro) doesn't like to be subject to stress too long, otherwise the life of it will be shorter. If you're using the Honda scissor jack, then you just have to be careful not to knock into the car, as it could fall. If it's windy too, I wouldn't recommend holding the car up with scissor jacks overnight (especially if you're using two of them).
Old Mar 25, 2006 | 10:05 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: is it okay to put a jack stand a while? (shamoo)
Who uses celcius? You will be fine as long as they are in a good position.
Old Mar 25, 2006 | 10:47 PM
xkrntamax's Avatar
Default Re: is it okay to put a jack stand a while? (SlammedDC2)
ohhhh okay.
Thank you guys!~!!
Old Mar 25, 2006 | 11:37 PM
rockNrollteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Who uses celcius? You will be fine as long as they are in a good position.</TD></TR></TABLE>
who uses celcius? who uses the metric system? what's that?
Old Mar 26, 2006 | 12:06 AM
SlamminS85's Avatar
Default Re: is it okay to put a jack stand a while? (rockNrollteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockNrollteg &raquo;</TD></TR><TR><TD CLASS="quote">who uses celcius? who uses the metric system? what's that?</TD></TR></TABLE>
yeah totally, i changed all my bolts to english system, its better
Old Mar 26, 2006 | 06:13 PM
xkrntamax's Avatar
well... my primary language is Korean....
Im not good at English that well.
I've been here almost 6year, but my English still suck!
anyway... Im using jack stand.
and I never use cessior jack. It looked very dangerious to me. hahah
Old Mar 26, 2006 | 06:56 PM
Dartanian's Avatar
Everyone else except for us?
The standard system is the most retarded thing ever created.
Old Mar 26, 2006 | 06:59 PM
Racermech's Avatar
Default Re: is it okay to put a jack stand a while? (Das Schmoo)
37C is over 100F
I have had the rear of my car on stands for a couple of monthes at a time, never had a problem.
Old Mar 26, 2006 | 08:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">Everyone else except for us?
The standard system is the most retarded thing ever created.</TD></TR></TABLE>
yeah i was being sarcastic
it was an ignorant thing to ask who used celcius, 'cause it's like asking who uses the metric system.
davidluko
Feb 25, 2008 03:25 PM
ziwang55
Honda Civic (2006 - 2015)
23
Oct 21, 2007 05:10 PM
KOREAN
Nov 15, 2005 09:06 PM
Daikirai
11
Dec 19, 2003 06:53 AM
Obie
Aug 22, 2003 09:21 AM
