Outer Cv Boot change
Old Jul 20, 2006 | 07:25 AM
Vitesse's Avatar
Default Outer Cv Boot change
Hey guy's I was just wondering if someone has an awesome write up on all the instructions on changing the outer CV boot on a 94 Rs. I did a quick search but all it came up with was minimal.
Thanks.
Old Jul 20, 2006 | 07:56 AM
rgaray's Avatar
Not much to it. Remove old boot, clean joint (brake cleaner or turpentine works), replace c clip, install boot, pack it w/ CV grease, fasten CV boot clips/bands, and install.
Old Jul 20, 2006 | 08:19 AM
Vitesse's Avatar
Default Re: (rgaray)
should i be able to use the existing clips and bands given they dont break when i remove them?... because im not sure if the boot i ordered is comming with new installation equip.
Old Jul 20, 2006 | 09:10 AM
jared99's Avatar
Default Re: (Vitesse)
yup
Old Jul 20, 2006 | 09:13 AM
RHDintegXsi's Avatar
Default Re: (jared99)
you cant reuse the old bands..i believe the kits come with everything you need. is it really worth rebuilding though? you can get rebuilt axles with warantee for ~$45-$75
Old Jul 20, 2006 | 09:16 AM
Vitesse's Avatar
Default Re: (SINFULintegXsi)
I know... i just bought a teg that need's to be saftied and certified... so i have to replace the outer cv boot.. the original has a small hole in it.
Old Jul 20, 2006 | 09:29 AM
jared99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi &raquo;</TD></TR><TR><TD CLASS="quote">you cant reuse the old bands..</TD></TR></TABLE>
Why not? I slid the old one off, took off the boot, put the new one on, and slid the old band right over top. Has worked fine since last November.
Old Jul 20, 2006 | 09:50 AM
Vitesse's Avatar
Beautiful.. I'll have to do that!
Thanks
beanbag
Transmission & Drivetrain
Dec 30, 2009 12:49 PM
Ben_si
12
May 24, 2005 08:44 AM
Cuong-nutz
22
Nov 19, 2004 11:50 AM
kb798
13
May 27, 2004 12:55 PM
jabroni95gsr
Dec 18, 2001 08:49 AM
