b18c1 vtec problem
Old Jul 21, 2006 | 07:03 PM
Sicarius82's Avatar
Default b18c1 vtec problem
when i hit vtec (~5800 rpm) the vtec will kick in, but then will cut in and out. i'm running stock motor with exception of CAI. i was told from a friend that the vtec solenoid has a filter which could get clogged. will this problem cause that? if so, how can i fix it? what else may cause this problem?
Old Jul 21, 2006 | 07:04 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: b18c1 vtec problem (Sicarius82)
Your VTEC engages at 4400 RPM with a stock B18C1. The IAB (secondary betterflies in the intake manifold) engage at 5600 RPM. Your VTEC is most likely fine. Check the IAB. It is most likely a bad solenoid for the vacuum.
Old Jul 24, 2006 | 06:57 PM
Sicarius82's Avatar
Old Jul 25, 2006 | 02:34 PM
RHDintegXsi's Avatar
also check your oil level..sometimes when your low on oil vtec will start kicking in and out
Old Jul 25, 2006 | 02:42 PM
Lauj87's Avatar
Default Re: b18c1 vtec problem (SINFULintegXsi)
^ check your vacume lines too might be a leak.
Fastwhip
Aug 2, 2007 03:58 PM
greddy13
Oct 24, 2005 10:40 AM
BlckSI
Aug 29, 2003 06:48 PM
b18coupe
Jun 20, 2003 06:01 AM
SpeedGyrl
Mar 16, 2003 04:23 PM
