ls vtec problem
Old Jul 18, 2006 | 08:04 PM
lsvtecna's Avatar
Default ls vtec problem
hey guys i just finish up my ls vtec setup and now i cant rev up past 3 rpm. does anyone have these problem before and how did u fix it?
Old Jul 18, 2006 | 08:07 PM
Backk InTheDA's Avatar
I hate everything
Default Re: ls vtec problem (lsvtecna)
What happens after 3grand? Does your car die, stutter? What happens.
Old Jul 18, 2006 | 08:08 PM
Lan's Avatar
Lan
Have you done any mods to the ECU? Did you wire VTEC properly to the ECU?
Old Jul 18, 2006 | 08:12 PM
lsvtecna's Avatar
before 3000 rpm the needle just drops and thats when i push back the clutch..and the vtec wiring is not connected yet but does that effect what is happening to my car? and i bought my ecu from pherable so yea.
Old Jul 18, 2006 | 08:18 PM
Lan's Avatar
Lan
I don't know first hand, I would suggsest you wire VTEC and go from there, I can almost guarantee that is your problem
Old Jul 18, 2006 | 09:12 PM
lsvtecna's Avatar
Default Re: ls vtec problem (Lan)
can it be like my sensors?
Old Jul 18, 2006 | 10:17 PM
jdmintegralsvtec's Avatar
does vtec kick in at 3k rpm? if it does then it is probably your vtec wires not being connected that is causing the problem.
Old Jul 19, 2006 | 01:14 AM
lsvtecna's Avatar
Default Re: ls vtec problem (jdmintegralsvtec)
its set at 4500...and can it be the iavc sensor or hoses connecting at the wrong places?
Old Jul 19, 2006 | 04:50 PM
lsvtecna's Avatar
i think its the fuel injectors because everytime i gas it hard or fast its just the rpm just drop and about to die but it doesnt
Old Jul 19, 2006 | 10:05 PM
dohcgarage@714's Avatar
you should check your ecu i had the same problem with my ls vtec i told my buddy to let me try his ecu on my car and it ran good but when we tried my ecu on his car it would go over 3 000 rpm so if one of your friends has a vtec ecu try theres on
Old Jul 20, 2006 | 06:30 AM
blackeg's Avatar
Default Re: ls vtec problem (dohcgarage@714)
maybe a loose ground???? are you getting any codes from the ecu??
Old Jul 20, 2006 | 02:09 PM
lsvtecna's Avatar
Default Re: ls vtec problem (blackeg)
i try my friend gsr ecu and it does the same thing so count that out..i clean my fuel injector count that out too...but i do have cel on but dont know what its showing...i think i dont have the 16 pin plug thing for the scan because i look under my dash near the fuses and its not der i guess when i bought it sumone took it out..
Old Jul 20, 2006 | 02:11 PM
Lan's Avatar
Lan
The SCS connector is what you need to find, passenger side. Jump it will a paperclip and you'll be able to read the code
Old Jul 20, 2006 | 02:14 PM
lsvtecna's Avatar
i cant even find the scs connector either..can u help me with any pictures or diagram
Old Jul 20, 2006 | 02:19 PM
Lan's Avatar
Lan
It is located above the ecu under the dash. It is a small two prong connector with two wires, the plastic part on mine is blue. It may be a different color I don't know
Old Jul 20, 2006 | 05:38 PM
coronadrinker's Avatar
sonnds like fuel for sure, did you happen to change the fuel rail by any chance
Old Jul 20, 2006 | 07:10 PM
sd,integ's Avatar
its your vtec not conected fo sure just try it by puting a wire on the silinoid and to the battery and rev it and come back if it dose not work . pease
Old Jul 21, 2006 | 05:09 PM
lsvtecna's Avatar
Default Re: ls vtec problem (sd,integ)
i didnt not change my fuel rail mostly everything is stock.....and with the vtec solnoid i wire it but when do u konw its working cuz when i wire it u can heard clicking sound does that mean it working?
Old Jul 21, 2006 | 08:24 PM
4d96gsr's Avatar
i know ur problem when u did or who ever did ur timing they didnt do it right! so its just timming check the exuast cam thank u come again and if iam right pm me thnakz u come again
Old Jul 22, 2006 | 11:29 AM
lsvtecna's Avatar
Default Re: ls vtec problem (4d96gsr)
the white mark is the tdc and the camshaft should be pointing upwards rite?
Old Jul 23, 2006 | 10:55 PM
4d96gsr's Avatar
yes correct but listen on the exaust cam theres markings and on the intake like two lil lines make sure those are alined with the arrows pointing up
the exaust one will look a lil tweeked out not pionting up but along its alined with the line ur cool
2.2accord
Jul 13, 2009 06:31 PM
integraluva04
Jun 29, 2008 10:27 AM
d16z6ef
11
Aug 3, 2007 06:36 AM
04civic17L
Honda Civic (2001 - 2005)
Jul 12, 2006 01:48 PM
