cr-vtec
Old Jul 22, 2006 | 04:17 PM
UBIntegrated's Avatar
Default cr-vtec
im thinking of building a cr-vtec engine but im curious as to what kind of rev limit the b20 block has stock. can anyone enlighten me on this????
Old Jul 22, 2006 | 06:34 PM
Default Re: cr-vtec (UBIntegrated)
Old Jul 22, 2006 | 07:00 PM
RJonathan's Avatar
I'm running a Stock B20B with a Stock B16 Head, and I only rev it to 8,000. I dont dare to do anymore than that.
Old Jul 22, 2006 | 07:27 PM
Itzmy91Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UBIntegrated &raquo;</TD></TR><TR><TD CLASS="quote">im thinking of building a cr-vtec engine but im curious as to what kind of rev limit the b20 block has stock. can anyone enlighten me on this????</TD></TR></TABLE>
Yeah man, i wouldn't rev much over 8k...maximum at 8.5k anywhere after that on a stock b20 and stock head, without sleeving, or aftermarket valve springs is just begging for the motor to blow up in your face. You should go pick up an ls block from the junkyard, sleeve it and build it up a bit and toss it in your crv. It would definately be unique...
Old Jul 22, 2006 | 08:00 PM
lVlemphizStylez's Avatar
Default Re: cr-vtec (Itzmy91Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Itzmy91Teg &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah man, i wouldn't rev much over 8k...maximum at 8.5k anywhere after that on a stock b20 and stock head, without sleeving, or aftermarket valve springs is just begging for the motor to blow up in your face. You should go pick up an ls block from the junkyard, sleeve it and build it up a bit and toss it in your crv. It would definately be unique...</TD></TR></TABLE>
valves arent the issue...its the rods i wouldnt take a stock b20/b18b bottom end to 8000 without at least arp rod bolts...
skerrttt
Mar 20, 2013 12:55 AM
b18c1del
Jun 2, 2007 07:14 PM
crashtest Sonny
19
May 14, 2003 12:03 PM
Jonathan_ED3
Aug 20, 2002 12:36 PM
nwarp
Jul 6, 2002 12:14 PM
