check engine codes
Old Jul 19, 2006 | 11:01 PM
project 2two9's Avatar
Default check engine codes
how do i fix these engine code- problems???
43- fuel supply system
10- intake air temperature
6- coolant temperature
Old Jul 19, 2006 | 11:05 PM
jdm_bones's Avatar
Default Re: check engine codes (project 2two9)
Code 6 might be a bad thermostat.
Code 10 might be because you are running an aftermarket intake...
Code 43...Hmm..have you installed a fuel rail or FPR recently...or maybe you need a new fuel filter!
Old Jul 19, 2006 | 11:07 PM
lVlemphizStylez's Avatar
Default Re: check engine codes (jdm_bones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">Code 6 might be a bad thermostat.
Code 10 might be because you are running an aftermarket intake...Not likely
Code 43...Hmm..have you installed a fuel rail or FPR recently...or maybe you need a new fuel filter!</TD></TR></TABLE>
an aftermarket intake will not affect this sensor in anyway...especially since its located on top of the intake manifold plenum
Old Jul 19, 2006 | 11:56 PM
jdm_bones's Avatar
Default Re: check engine codes (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">
an aftermarket intake will not affect this sensor in anyway...especially since its located on top of the intake manifold plenum</TD></TR></TABLE>
It will if it's a coldair intake guy!
Old Jul 20, 2006 | 12:17 AM
It will if it's a coldair intake guy!</TD></TR></TABLE>
no it will not...and im not going to argue it with you either..an intake will not throw that sensor off...
Old Jul 20, 2006 | 09:26 AM
jared99's Avatar
Could be problem with air intake temp sensor?
Old Jul 21, 2006 | 11:33 PM
nah i dont have a fuel rail... everythign is basically stock on the car... js the aftermarket intake
zcivicz
Jan 29, 2017 05:21 PM
alb_accord
Aug 13, 2007 09:53 AM
boostjunkie757
Jun 16, 2005 10:10 AM
EFz6er
Mar 18, 2005 09:29 AM
oO
Apr 10, 2003 07:03 AM
