Integra GSR Problems...
Old Jul 22, 2006 | 09:41 AM
meagainsttheworld's Avatar
Default Integra GSR Problems...
My buddy bought a gsr with a rebuilt B18C1 engine... the problem is that he runs way slower than what he should be...
runs 16's which is horrible...
but yeah, he said that vtec is set to hit at 4 grand but when he drives it... you can feel it kick in at 4 a little but then it hits hard at 6 like vtec should hit... "like it needs to build up pressure"
im just wondering does anyone know what is wrong with it? cuz i might be thinking of buying it
Old Jul 22, 2006 | 09:44 AM
Lan's Avatar
Lan
Default Re: Integra GSR Problems... (meagainsttheworld)
GSR's will have a 'feeling' of VTEC kicking in 2 times throughout each gear because of the design of the Intake Manifold. Do a compresion test to see if there are any problems internally
Old Jul 22, 2006 | 10:17 AM
someone told him that the vtec solenoid needs to be cleaned... could that be the problem?
Old Jul 22, 2006 | 10:36 AM
bump
Old Jul 22, 2006 | 11:25 AM
diagnostic's Avatar
Default Re: (meagainsttheworld)
if the vtec is coming on, chances are that the solenoid is working fine. if it werent, you might set a vtec system malfunction code.
but it wont hurt either way to remove it and clean it out. so go for it!
Old Jul 22, 2006 | 11:33 AM
RHDintegXsi's Avatar
Default Re: (diagnostic)
is it a stock rebuild? why is vtec set at 4k? first off if its stock i would run stock ecu w/ stock vtec engagement. maybe do a compression/leak down test..maybe even a baseline dynorun
16's? thats not good but its hard to use 1/4 times alone to determaine how fast it is...there are a lot of variables..traction..60ft times..shift point.
Old Jul 23, 2006 | 09:22 AM
bump
Old Jul 23, 2006 | 11:37 AM
DC2SIR-G's Avatar
* B A N N E D *
what ECU is he running? vtev should kick in at 4400 RPM and butterflies open at 5700 RPM. is it a bone stock GSR?
Old Jul 23, 2006 | 11:56 AM
Default Re: (DC2SIR-G)
hes got I/H/E but thats it... im thinking that it does kick in at 4400 and butterflies open at 5700 but he just rounded up... donno
Old Jul 23, 2006 | 01:37 PM
gsrob's Avatar
There's no reason for VTEC to come on any earlier than what is stock for a stock motor. Honda obviously has it set up that way for a reason. The motor in that trim is optimized for that VTEC setting.
Old Jul 23, 2006 | 01:57 PM
Comp97GSR's Avatar
Next time Vtec hits, hit it back.
Old Jul 23, 2006 | 03:31 PM
so what should the compresion be for a gsr? b18c1?
Old Jul 23, 2006 | 05:08 PM
Jose1995GSR's Avatar
how about something simple....check to make sure there is enough oil in it. I know it seems kinda stupid, but mine burned oil and it ran slow when it needed oil. You could also check the spark plugs, wires, and cap.
HondacivDX
Feb 19, 2012 06:52 PM
ryintegra32
May 28, 2008 04:03 PM
t_lager
Aug 5, 2005 02:54 PM
RedEj8
Jul 1, 2005 10:30 PM
JdmFront619
Dec 23, 2003 10:48 PM
