VTEC is nuts!
Old Oct 2, 2006 | 04:10 PM
drkspid4's Avatar
Default VTEC is nuts!
ok so i rewired vtec to a FACTORY HONDA WIRING DIAGRAM of a 93 GSR and im STILL throwing VTEC Solenoid Valve (code 21) and VTEC Oil Pressure Switch (code 22) codee list is located here -- http://www.phearable.net/tech/....html
anywho what gives?
MY CAR IS OBD1
also i noticed that the date stamped on the head of my motor is 91 so its out of a 88-91 civic/crx JDM and that is OBD0 and my ecu is out of a 93 civic and thats obd1.... could that be a problem?
if the ecu is the problem which i think it is... which ECU would be better the...
PR3 1989-1991 Acura Integra XSi/RSi
PR3-J00 1992 Acura Integra JDM B16A EF 8/9
PR3-J51 1992 Acura Integra JDM B16A EF 8/9
ECU list located on http://www.phearable.net/tech/wiring/ecus.html
Old Oct 2, 2006 | 05:49 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: VTEC is nuts! (drkspid4)
JDM VTEC solenoids typically do not have the VTEC Oil pressure switch. That could be your problem if you have a USDM ECU that is looking for that switch.
Beasting EF22
22
Aug 23, 2011 02:33 PM
got wide
Apr 3, 2007 04:57 PM
EF8IGHT
Jan 13, 2006 05:37 AM
