NEED HELP PULLING MOTOR....
Old Oct 1, 2006 | 09:40 AM
Elbowpunk's Avatar
Default NEED HELP PULLING MOTOR....
hello i gots a 91 da b18 motor that i need to pull to put into another car, well its stuck at this point and it wont go any farther down and i cant pull up... what the expletive should i do ??? i am getting so pissed
it looks like no movement from the back of the motor... and all the mounts are off.. all the wires off.... idk what to do...
Old Oct 1, 2006 | 10:11 AM
Fat Chick Magnet's Avatar
wow i laughed for 5 seconds after i saw the 1st picture.
ummm did you get the axle out? you can also drop the motor down on the ground and jack the car all the way up and pull it out.
Old Oct 1, 2006 | 10:15 AM
projectTeG's Avatar
your lifiting it wrong, you need to put one of the chains on the other side of the engine to offset it.
Old Oct 1, 2006 | 10:16 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (dc2rtek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2rtek &raquo;</TD></TR><TR><TD CLASS="quote">you can also drop the motor down on the ground and jack the car all the way up and pull it out.</TD></TR></TABLE>
I have also done this. Let me sound like a ghetto mechanic for a minute, me and my buddy swapped our first motor and dropped the motor on the ground, and used the engine lift to pull the front end of the car up so we could slide the motor out from underneath it. It was ghetto but it worked. Good luck.
Old Oct 1, 2006 | 10:19 AM
Elbowpunk's Avatar
wait... y u laugh...
and...
i dont have a big enough jack to raise it that much... would it help to have all 4 jack stands or have the tries on the back ?? and ya i got all the axels off.. the crank pulley is resting my the side mount area, it wont go down or the pulley will break... i cant push it over to the tranny side to bring it down, idk
Old Oct 1, 2006 | 10:21 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (Elbowpunk)
Use the engine lift to pul the car up and get the motor out the bottom. Just make sure you have a big friend (230+) over the stand on the base of the lift so it doesn't tip over.
Old Oct 1, 2006 | 10:28 AM
Elbowpunk's Avatar
where do i attach the chains to ?? the frame or something ?
Old Oct 1, 2006 | 10:30 AM
SlammedDC2's Avatar
Semper Fidelis
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elbowpunk &raquo;</TD></TR><TR><TD CLASS="quote">where do i attach the chains to ?? the frame or something ?</TD></TR></TABLE>
Thats what we did.
Old Oct 1, 2006 | 10:38 AM
mattcivic's Avatar
Default Re: (SlammedDC2)
wow get your self some pry bars and a friend and just start lowering and lifting the motor move it side to side ect ect it will come out. next time u pull a motor get a dolly to drop the motor onto with the cherry picker then use the cherry pick to lift the car over the motor. after u take the motor out from the bottom of a honda u will never go out the top ever again. or if your like me today im pulling my motor but i cant get my hands on a cherry picker so i pulled the tranny out already and now im gunna drop the motor tip it back and pull it out from under the car..... GOOD LUCK!!!
is the shift linkage unhooked?
Old Oct 1, 2006 | 12:13 PM
arrojj's Avatar
Default Re: (mattcivic)
dude that motor is disgusting and its not rocket science not that hard to pull a motor out...... yeah check the shift linkage
Old Oct 1, 2006 | 12:30 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: (arrojj)
why dont you try hooking the chain up differently? Put one part on the tranny side to gain more play
Old Oct 1, 2006 | 12:51 PM
lilpastrana's Avatar
Default Re: (It's*BOLO!!)
looks like your hitting on the tranny. did you take the mount off itself from the frame ?
Old Oct 1, 2006 | 01:01 PM
the_grinder's Avatar
Default Re: (lilpastrana)
To the original poster ignore what everyone has said, it seems that they have never pulled a motor themselves.
Of course the shift linkage and shafts are removed.
I would lower it back to the origninal position. Rehook the chain from the front of the motor closer to the tranny side to balanace it out, theres a spot for it, you should be able to see it.
Also when lifting a motor form the top in the DA, it makes it a lot easier to remover the radius arms and the front subcradle. Doing this is only 4 or so 17mm and a 6 or so smaller bots holding abother bar perpindicular to it. When its all removed you can lower the motor to the ground and then twist it so it can come out easier, so it will clear the passenger side mount.
Old Oct 1, 2006 | 01:46 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (the_grinder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_grinder &raquo;</TD></TR><TR><TD CLASS="quote">I would lower it back to the origninal position. Rehook the chain from the front of the motor closer to the tranny side to balanace it out, theres a spot for it, you should be able to see it. </TD></TR></TABLE>
lol, you trying to say the motor has to be perfectly level to pull it out??
Old Oct 1, 2006 | 02:08 PM
THX-GSR's Avatar
Default Re: (CleanLikeJdm)
From the looks of your pictures, you have a tire holding the tranny from dropping to the concrete slab. Remove the tire holding the tranny, and re-hook the lifting points
in the front mount. (the most forward part of the motor} once you lift the motor
the angle will change, to more vertical position, I suggest removing tranny oil out of the
transmission, it will leak out on the floor..
Old Oct 1, 2006 | 02:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">
lol, you trying to say the motor has to be perfectly level to pull it out?? </TD></TR></TABLE>
Of course not, but I find its a lot easier if its somewhat level. He has nothing to lose by rehooking it and trying a second attempt so he can lift it out, otherwise he will have to lift the motor 10 feet in the air for the tranny to clear the rad support.
Old Oct 1, 2006 | 02:15 PM
BTW, what hapened to the car? If your still having troubles and not keeping the car just use a sawzall, LOL
Old Oct 1, 2006 | 02:30 PM
SlammedDC2's Avatar
Semper Fidelis
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_grinder &raquo;</TD></TR><TR><TD CLASS="quote">To the original poster ignore what everyone has said, it seems that they have never pulled a motor themselves.
I have pulled a few motors, and my preferred method is to drop the motor on the ground, use the engine lift to lift the car over the motor and slide it out. What works for me might not work for everything.
Old Oct 1, 2006 | 02:38 PM
Guess whos bizzack
don't worry slammed, your method is good, that guy thinks only his post is good even though he just copied what i said
Old Oct 1, 2006 | 02:42 PM
SlammedDC2's Avatar
Semper Fidelis
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s*BOLO!! &raquo;</TD></TR><TR><TD CLASS="quote">don't worry slammed, your method is good, that guy thinks only his post is good even though he just copied what i said </TD></TR></TABLE>
Oh, I just think it's funny when people assume that no one else has done what they have done.
Old Oct 1, 2006 | 03:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
I have pulled a few motors, and my preferred method is to drop the motor on the ground, use the engine lift to lift the car over the motor and slide it out. What works for me might not work for everything.</TD></TR></TABLE>
Never meant to be that ignorant, I just read a lot of people giving some really stupid advice such as the driveshaft and shift linkage.
I only drop from the bottom, if I am using ahoist, otherwise, I go from the top. Different ways same result, right. But he's already working on it that way so continue.
Old Oct 1, 2006 | 03:44 PM
Go expletive yourself
Old Oct 1, 2006 | 04:20 PM
Guess whos bizzack
lol
Old Oct 1, 2006 | 04:45 PM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_grinder &raquo;</TD></TR><TR><TD CLASS="quote">Go expletive yourself</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s*BOLO!! &raquo;</TD></TR><TR><TD CLASS="quote">lol</TD></TR></TABLE>
Ohh, burn.
Btw, I think you meant to say fu<u></u>ck.
Old Oct 1, 2006 | 04:53 PM
Guess whos bizzack
potty mouth
