Fuel problems, need help
Old Oct 2, 2006 | 10:22 AM
Azazel1507's Avatar
Default Fuel problems, need help
Car is a 94 GS with a B20B swap. suddenly the car would not start but cranked and got spark so i sent it to a small garage, my mechanic replaced the in-tank fuel pump but no results. He ran a direct lead to the pump from battery and the fuel pressure guage under hood read 22 pounds but needs 40 pounds. we do not have a wiring diagram and the swap was done a little half-assed with wires everywhere. do you guys have a good wiring diagram for the teg or any ideas what could be causing the pump to not create enough pressure (bad relays, fuses )?
Modified by Azazel1507 at 12:36 PM 10/2/2006
Old Oct 2, 2006 | 11:07 AM
DC2 Mang's Avatar
Default Re: Fuel problems, need help (Azazel1507)
you could have a bad relay causing a power drop and therefor not feeding a powerful enough signal to the fuel pump
there could also some sort of damage in the fuel line causing it to use pressure
or even a faulty ecu
B16-CRX
Oct 4, 2010 04:32 PM
zccr-xsi
Mar 29, 2008 04:15 AM
littlecrxVTEC
Dec 26, 2007 02:54 PM
skoolz4loserz
May 10, 2006 06:55 PM
hwnstyle21
Sep 8, 2002 02:14 AM
