crome
Old Oct 2, 2006 | 04:23 PM
skata89's Avatar
Default crome
Im planning to get my car tuned soon with crome. its a 96 jdm itr, with ihe and adjustable cam gears. I was wondering though if I need anything else to help with tuning and to get the most power as I can. Like do I need to get a vafc or fpr etc.
Old Oct 2, 2006 | 05:31 PM
integ401's Avatar
Default Re: crome (skata89)
you won't need the Vafc. Crome will do it all for ya but you need your ecu chipped
Old Oct 2, 2006 | 07:01 PM
InfamousDC2FI's Avatar
Default Re: crome (integ401)
If your serious about tuning invest in a quality wideband sensor, i cant see how you can tune without one
Old Oct 2, 2006 | 07:24 PM
95dc2teg's Avatar
Default Re: crome (InfamousDC2FI)
If he takes it to a tuner shouldnt they have one? (wideband)
Old Oct 2, 2006 | 07:32 PM
Default Re: crome (95dc2teg)
yes if he takes it to a tuner...but where is the fun in that? I personally would opt to have a wideband in my car 24/7 just because of peace of mind...just think what if something takes a crap on you while your running through the gears WOT and your motor isnt getting as much fuel as it should? boom....
i know his motor is just n/a and a wideband wouldnt be as needed, but in a boosted application I wouldnt run a car without one...
Old Oct 2, 2006 | 07:36 PM
95dc2teg's Avatar
The are definately worth the piece of mind. Kinda wish i had the money to get one....
Old Oct 2, 2006 | 07:46 PM
integ401's Avatar
haha yeah thats what i'm doing is running a lc1 wideband in my car full time. And just got a Lma 3 to see what vacuum i'm runnin because my datalogging doesn't want to work .
Old Oct 2, 2006 | 08:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ401 &raquo;</TD></TR><TR><TD CLASS="quote">haha yeah thats what i'm doing is running a lc1 wideband in my car full time. And just got a Lma 3 to see what vacuum i'm runnin because my datalogging doesn't want to work . </TD></TR></TABLE>
are u datalogging through the ecu or the lc1?
Old Oct 2, 2006 | 08:15 PM
integ401's Avatar
i have to connect the lc1 to the lma3 and then to the laptop. I can't get it through the ecu to work for some strange reason and i tried everything
Old Oct 2, 2006 | 08:23 PM
it took me a while to get it working through the ecu too, i dont know if this helps but i was reading on pgmfi.org forums that on some of the ecus you have to remove the j12 jumper from the board, after i did that datalogging worked perfect.
Old Oct 2, 2006 | 08:30 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InfamousDC2FI &raquo;</TD></TR><TR><TD CLASS="quote">it took me a while to get it working through the ecu too, i dont know if this helps but i was reading on pgmfi.org forums that on some of the ecus you have to remove the j12 jumper from the board, after i did that datalogging worked perfect. </TD></TR></TABLE>
Yes, Crome and Hondata must have J12 removed to datalog through the ECU. Uberdata doesn't.
I run a wideband all the time. I have the Zeitronix wideband with 3.5 bar boost sensor and display screen.
ShowpowJojo
Dec 16, 2008 08:35 PM
StreetRacinThug
Nov 28, 2006 12:16 PM
2lobes1engine
May 16, 2004 04:06 PM
youngvedder
Jan 19, 2004 03:18 AM
ActiveAero
Oct 25, 2001 05:24 AM
