Huge rattle?
Old Nov 13, 2006 | 06:23 PM
DA 4 Lyfe's Avatar
Default Huge rattle?
I have a huge rattle from my exhaust or something. As i'm taking off from 1st gear you can hear it and when I rev it at constant from 2-4K it rattles heavly. Any ideas what this could be?
Old Nov 13, 2006 | 06:25 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Huge rattle? (DA 4 Lyfe)
Check the heat shield on top of your catalytic converter. If it is loose, remove it.
Old Nov 13, 2006 | 10:25 PM
Marz's Avatar
Where is it rattling from? Find out...could just be a broken mounting bracket/weld.
Old Nov 13, 2006 | 10:55 PM
davidluko's Avatar
Default Re: Huge rattle? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Check the heat shield on top of your catalytic converter. If it is loose, remove it.</TD></TR></TABLE>
Why remove it? Just tighten it back up.
To the OP, it's probably just some heatshield.
Old Nov 14, 2006 | 04:49 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Huge rattle? (Hatch_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote">
To the OP, it's probably just some heatshield.</TD></TR></TABLE>
When the heat shield on the catalytic converter rattles, it typically has broken free of the mounting bolts at the corners. The only way to reattach it in that case is to weld it.
Old Nov 14, 2006 | 07:06 AM
teg_timmyc's Avatar
My exhaust sheild rattled realy bad, so i just took it off. its nicer now that it is off b/c my short shifter doesn't hit it and its easier to take off the shift linkage.
Old Nov 18, 2006 | 01:25 PM
DA 4 Lyfe's Avatar
I found out that it wasnt my cat. it was my resonator. I want to get a new cat back exhaust for my integra. I have a 92 DA right now and was wondering if a 94 exhaust could maybe fit on my car with light modifications done to it? I'm in need of a new cheap exhaust ASAP.
Old Nov 18, 2006 | 03:31 PM
95 integra's Avatar
Default Re: (DA 4 Lyfe)
BTW, alot of times the "A-pipe" (ie the bottom half of the header) rattles. It has a pipe inside a pipe that loves to rattle later in life. The DC exhaust is grossly different then the DA, so its not going to fit....even with "minor" modification. You might as well make exhaust from scratch then try to refit it.
Old Nov 18, 2006 | 03:37 PM
Presto800's Avatar
Removing the heat shield = parking on grass and catching it on fire = getting sued by state = your phucked.
Dont remove your heat shield. Go get it re-welded.
This has happened with one of the members of my family and he is now serving a very long dept repayment for burning down a large area of grass and forest. Not like a whole national forest but neighborhood size.
Old Nov 18, 2006 | 03:50 PM
95 integra's Avatar
Default Re: (Presto800)
Removing the heatshield ABOVE the cat doesnt have anything to do with grass that is underneath it catching on fire.
Old Nov 18, 2006 | 04:13 PM
Presto800's Avatar
but dont most lower heat shields come loose from bottoming out and crap?
Old Nov 18, 2006 | 04:17 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Presto800 &raquo;</TD></TR><TR><TD CLASS="quote">but dont most lower heat shields come loose from bottoming out and crap?</TD></TR></TABLE>
The top shield typically comes off on Integras. Water must collect there carrode the corners.
Old Nov 18, 2006 | 04:19 PM
95 integra's Avatar
Bottoming out? Even on a slammed car, my cat never scrapped and certainly not to the point of falling off. Plus, its not like you're driving your slammed integra through the grassy knoll. Also, the cat/bottom of the header area dont really get hot enough to light grass on fire unless its really really really dried up.
Old Nov 18, 2006 | 09:40 PM
DA 4 Lyfe's Avatar
I was thinking about just getting a new muffler, and getting 2.25 inch piping underneeth and getting an N1 Burn T-Tip muffler from ebay. Should I do that or is it not worth it? Right now all I have is a 4 inch fart can. I have an intake and header and I would like to gain as much HP out of an exhaust as I possibly can. Help would be great
allricedout
Suspension & Brakes
12
Aug 7, 2008 05:55 AM
stackz
Welding / Fabrication
May 7, 2007 04:59 PM
RACEPAK
11
Mar 23, 2007 01:50 PM
JDM Factor
Aug 13, 2005 08:45 AM
silver_nteg
Nov 15, 2003 06:27 PM
