Is this strong enough?
Old Nov 12, 2006 | 03:18 PM
AViciousTHRUST's Avatar
Default Is this strong enough?
I cant get the axle bolt out, i tried the breaker bar and yanked on that **** but still no luck, so I went and bough that goodyear 200ft lb cordles impact wrench but Im not sure if that will do the job, what do yoiu guys think?
Old Nov 12, 2006 | 03:33 PM
IHTFP's Avatar
Default Re: Is this strong enough? (AViciousTHRUST)
if you already bought it, try it out
ive always been able to get it using a jack handle on the end of a 1/2" drive ratchet. and if it breaks, craftsmen replaces it for free
Old Nov 12, 2006 | 04:33 PM
Dogginator's Avatar
Daisy... Daisy...
Spay the axle nuts with PB blaster and let it sit for a day if possible. Be sure to unbend the divit on the axle nut as well. I used a 4' cheater bar to loosen mine.
Old Nov 12, 2006 | 04:49 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: Is this strong enough? (Dogginator)
i always just use the extension from my jack as a torque bar
Old Nov 12, 2006 | 08:19 PM
DraginTeg93's Avatar
we just did my buddys . what a Bit*h it was to get that nut off . we broke 2 brakerbars and we also heated the nut up too
Old Nov 12, 2006 | 09:25 PM
Default Re: Is this strong enough? (DraginTeg93)
damn! well hopefully the impact wrench will work, if not ill return it and see if I can get an ir compressor and some air tools that are maybe in the 400ft lb range
Old Nov 12, 2006 | 11:45 PM
davidluko's Avatar
Default Re: Is this strong enough? (It's*BOLO!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by It’s*BOLO!! &raquo;</TD></TR><TR><TD CLASS="quote">i always just use the extension from my jack as a torque bar</TD></TR></TABLE>
So do I. And make sure you straighten out that bend in the nut like Dogginator said before trying to unbolt it.
ricerodder91EX
33
Apr 14, 2007 12:24 PM
91-lsvtecsi
Suspension & Brakes
Oct 18, 2005 07:57 AM
citrusdrop
18
Jul 19, 2004 02:35 PM
gsrcivic619
10
Jan 5, 2004 04:07 PM
deviant1
13
Oct 23, 2003 07:29 AM
