LSD install
Old Nov 11, 2006 | 02:07 PM
Baron55's Avatar
Default LSD install
I recently had my jdm type r lsd put into my 98 gsr. My car already had ball bearings on the open diff. So i just replaced them with new ones, but my mechanic never changed the shim. The tranny already had the 1.0 shim and he told me that i didnt have to change it. So far everything works fine. Anyways, should my tranny be ok?
Old Nov 11, 2006 | 07:48 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: LSD install (Baron55)
Did the mechanic check the clearance with a feeler gauge? It is possible that the 1mm shim was the correct shim for the new differential.
Old Nov 12, 2006 | 05:22 PM
Baron55's Avatar
no he didnt
Old Nov 12, 2006 | 05:35 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (Baron55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">no he didnt</TD></TR></TABLE>
That is not good. I check my differential clearance and then handed the feeler gauges to my buddy for an independent verification.
Old Nov 12, 2006 | 08:47 PM
blkb18's Avatar
There is also a torque spec you can go by. With the trans assembled and in neutral, turn the diff with a needle style torque wrench. You will need a special tool to turn the diff, i made one out of a socket and a piece of steel rod. It should take "x" ammount of torque to turn the diff, the range is somewhere around 20 ft. lbs i think. It's been soo long since i did mine. Obviously if it rotates too easily you need a wider shim and vise versa. Good luck.
Old Nov 13, 2006 | 04:37 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: LSD install (blkb18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkb18 &raquo;</TD></TR><TR><TD CLASS="quote">There is also a torque spec you can go by. With the trans assembled and in neutral, turn the diff with a needle style torque wrench. You will need a special tool to turn the diff, i made one out of a socket and a piece of steel rod. It should take "x" ammount of torque to turn the diff, the range is somewhere around 20 ft. lbs i think. It's been soo long since i did mine. Obviously if it rotates too easily you need a wider shim and vise versa. Good luck.</TD></TR></TABLE>
He has ball bearings, not tapered roller bearings. You use a feeler gauge for the ball bearings. The only rotational torque spec for the ITR LSD check the operation of the LSD.
jdm inc
Transmission & Drivetrain
10
Sep 11, 2011 03:29 PM
nickromeo
Mar 7, 2005 06:07 PM
torqueless
Jan 21, 2005 09:03 PM
Heisdan
Mar 23, 2004 03:48 AM
yellow eg
Sep 24, 2003 11:47 PM
