LS vs b20 compression?
Old Jul 21, 2007 | 09:04 AM
da9blk1's Avatar
Default LS vs b20 compression?
the Ls is 9.1:1 right?
and the b20b is 8.8:? is that correct?
whats the diffrence like...in LS vtec, and b20"B" vtec?
Old Jul 21, 2007 | 10:24 PM
doood's Avatar
been there done that
Default Re: LS vs b20 compression? (da9blk1)
compression will either go up, how much depends on what head you use.
Old Jul 22, 2007 | 09:53 AM
da9blk1's Avatar
Default Re: LS vs b20 compression? (doood)
the same exact head, b16. i took it off my b20b and gave it to my friend with an Ls. it made a big diffrence, on the ls. just wanted to know the diffrence
Old Jul 22, 2007 | 09:58 AM
SIC_jdm_da9's Avatar
its the CP the b20b has... its so low but if you make the CP better it would run harder then the LS, if you had the b20 with 9.6 or 9.2 cp it would be runnin....
jdm89crxhf
Dec 9, 2011 05:16 PM
IntegraGSR(-1)
Jul 10, 2005 09:52 PM
bryanb2
Jan 18, 2005 07:39 PM
Sassafrass
Jan 8, 2003 12:41 PM
