Engine Light comes on when vtec kicks in in 3rd
Old Jul 22, 2007 | 06:13 PM
Brian2.0's Avatar
Default Engine Light comes on when vtec kicks in in 3rd
1996 GSR, H/E with test pipe, So yea, when i do a hard pull everything is great 1 - 3 but if i hold through third and shift hard in to 4th, my engine light comes on, and vtec stops kicking in, also, when at highway speed, say 65 70, and i down shift to forth to get around someone or just speed up, dose same thing, any ideas what this might be? any input would help, thanks guys...
Modified by Brian2.0 at 7:43 PM 7/22/2007
Modified by Brian2.0 at 7:57 PM 7/22/2007
Old Jul 22, 2007 | 07:10 PM
Brian2.0's Avatar
Default Re: Engine Light comes on when vtec kicks in in 3rd (Brian2.0)
anyone have a clue?
Old Jul 22, 2007 | 07:18 PM
VTEC_Du_Ma_Mai's Avatar
it might have something to do with you having a test pipe and the o2 sensor not reading correctly. you might be in limp mode, but i dont know why you arent in limp mode before 4th gear. try searching test pipe problems and o2 sensor problems.
Old Jul 22, 2007 | 07:19 PM
Brian2.0's Avatar
Default Re: Engine Light comes on when vtec kicks in in 3rd (VTEC_Du_Ma_Mai)
thanks ill check it out.
Old Jul 22, 2007 | 08:10 PM
climb_on's Avatar
vtec works off of oil pressure make sure that your oil level is good and your not loosing pressure anywhere
Old Jul 22, 2007 | 08:13 PM
teggsr925's Avatar
Default Re: Engine Light comes on when vtec kicks in in 3rd (climb_on)
u might just be hitting the rev limiter
Old Jul 22, 2007 | 08:16 PM
alexisthemovie's Avatar
vtec is at 4400, nowhere near the rev limiter.
Old Jul 23, 2007 | 03:42 AM
Brian2.0's Avatar
Default Re: Engine Light comes on when vtec kicks in in 3rd (teggsr925)
thanks, i think i may have a leak somewhere, there was a bit of oil on the block, looks like it was comming from the cam seal or behind the vtec noid. have to pull it apart today to see what happens, thanks guys.
Old Jul 23, 2007 | 04:48 AM
WishinItWas's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by climb_on &raquo;</TD></TR><TR><TD CLASS="quote">vtec works off of oil pressure make sure that your oil level is good and your not loosing pressure anywhere</TD></TR></TABLE>
Yup, my old hatch did the same thing after i swapped it, she was low on oil.
Old Jul 23, 2007 | 03:03 PM
Brian2.0's Avatar
Default Re: Engine Light comes on when vtec kicks in in 3rd (WishinItWas)
yea, i went to auto zone and had them pull codes, they didnt know much about them tho, anyone know where i can look them up?
Old Jul 23, 2007 | 06:09 PM
hard charging 929's Avatar
what's the code?
mfzbike
Feb 10, 2006 02:06 PM
rbdynamics
Dec 15, 2005 05:46 AM
sivicman
May 15, 2002 01:17 PM
TGUNNER
Nov 30, 2001 04:26 PM
Pure R Racer
Nov 28, 2001 06:33 PM
