gsr throwin codes
Old Jul 22, 2007 | 06:51 AM
del_slow420's Avatar
Default gsr throwin codes
ok its not my car im helpin out a friend.. he was racing and wsa at 8200 and mis shifted from 3rd to 2nd bent all of his exaust valves and broke to vavle guides. bought another head i swapped it in changed out all the gaskets torqued everything down used arp head studs. he called me up the other night and said now its throwing code for "cylinder 1 misfire" and and another misfire not surewhat the code was he also said his car seems to be burning alot of gas.. sorry for the run on sentence can you guys please give me some opinions whats wrong
Old Jul 22, 2007 | 07:44 AM
hybrid98's Avatar
Default Re: gsr throwin codes (del_slow420)
well just to let you know, when you get two misfire codes it prolly is bent valves. that is exactly what happened to mine. compression test is necessary
Old Jul 22, 2007 | 09:13 AM
Default Re: gsr throwin codes (hybrid98)
yea i had just bought a new compression tester and used it on my friends prelude and it had alot of uses and the cylinder was full off oil and the pressure killed the gauge...
Old Jul 23, 2007 | 06:30 AM
anyone else need some help sorry i forgot to say it is obd2 2000..
tamadrummer1120
12
Jan 10, 2012 05:02 PM
caspers_hatch
May 23, 2007 12:50 PM
blowme
May 2, 2005 04:38 AM
1hotintegra
Jun 11, 2003 02:07 PM
