code 1 and 4 i need help fast
Old Aug 17, 2007 | 03:09 PM
falcor's Avatar
Default code 1 and 4 i need help fast
I have a 1990 integra with a Sir2 B16a 0db1 I hade washed the moter and then it was messed up i put a new IAC,O2 not the universol one ether,TPS, Distributor and the car is still messed up the idle jumps up and doun at 1500 to 1700 like ra ra ra ra ra ra ra ra and the codes will not go away i looked at the wireing it is right sorry about not tiping so you know what i am talking about
Modified by falcor at 1:18 PM 8/18/2007
Old Aug 17, 2007 | 05:59 PM
JasonST's Avatar
Default Re: code 1 and 4 i need help fast (falcor)
What did u try and say? U got an obd0 to obd2 conversion harness? What year motor and car? Check ur o2 sensor make sure it's plugged in.. Check the continuity of the wires and make sure the wires are going to the correct ecu pinouts.
Old Aug 17, 2007 | 11:14 PM
davidluko's Avatar
A bad o2 won't make your idle bad. I really don't understand what you said about obd0 and obd1, but you need to provide more information about the engine/ecu/etc. It could be your IACV, TPS sensor, etc. Search, there's TONS of threads about high/jumping/bad idle.
Greg Goumas
Jan 16, 2019 03:05 PM
Circaskaterr
Engine Management and Tuning
Jan 1, 2010 04:29 PM
punkracer
Feb 1, 2009 06:57 PM
red_EF9Si
Sep 19, 2005 01:24 PM
r2d97
Aug 3, 2005 07:16 PM
