Help with Pivot Tachometer Install
So my friend gave me his Pivot Tachometer but he doesent remember how to wire it back up to a Integra....also It didnt come with any instructions.. all I know is that it has 4 wires...White / Black / Red / ORange .... I believe Black is Ground and Red is to a 12v source... but where do i hook up the other two wires???Pix will be helpful.....Thanks in Advance
All wires can be hooked up to wires behind the gauge cluster.
<u>Tachometer Wire ---> Cluster Harness Wire</u>
Black ---> Black (or dash bolt) [ground]
White ---> Red/Black [illumination]
Red ---> Black/Yellow [12v]
Orange ---> Blue [signal]
for the BLUE "signal" wire.... do i tap it to the harness that only has 3 wires? (farthest yellow harness to the right if you were facing the gauge cluster)
Dc2 Powered
Sep 23, 2004 05:26 PM
diagram, gauge, honda, instaling, install, installation, integra, manual, meter, onstallation, pivot, rpm, tach, tachcometer, tachometer, wiring
