96spec 4x114 conversion
Old Oct 1, 2007 | 03:46 PM
TastyDragon's Avatar
Default 96spec 4x114 conversion
i have a 00 gsr and im planning on doing tha itr 4x114 conversion soon and i have some questions. is it pretty much a direct bolt on to my gsr? theyre complete with im guessing hub and rotors, and calipers, control arms, trailing arms. do i need type r lca's? new brake lines? im pretty new to this any clarity would help. thanks.
Old Oct 1, 2007 | 03:58 PM
Usagi Yojimbo's Avatar
From: Dont say my car is topless say the titties is out
Default Re: 96spec 4x114 conversion (TastyDragon)
AFAIK, it's a complete bolt on. If you'd like to change the brake lines to some brand of braided lines or something it would be the best time. You don't need Type R lca's as the lca's are the same as a non-R integra's. The only problem you may run into would be new rotors, which would be easily solved by redrilling some 4x100 rotors. Hope this helps
Old Oct 2, 2007 | 03:26 PM
Default Re: 96spec 4x114 conversion (Usagi Yojimbo)
with tha 4x114 could i upgrade to type r lca's in tha future? and is it recommended that i get new rotors when i do tha swap? how long do you keep tha rotors for?
Old Oct 2, 2007 | 03:36 PM
myfirstdc2's Avatar
why are u changing it for? is it for the purpose of a wheel u want?
Old Oct 2, 2007 | 04:33 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TastyDragon &raquo;</TD></TR><TR><TD CLASS="quote">with tha 4x114 could i upgrade to type r lca's in tha future? and is it recommended that i get new rotors when i do tha swap? how long do you keep tha rotors for?</TD></TR></TABLE>
Good luck finding the 4x114.3mm rotors for the 96 Spec R here. The brakes are the same size as any 94-01 non ITR. The ITR LCAs can be installed on your GSR.
Old Oct 2, 2007 | 07:12 PM
myfirstdc2's Avatar
Default Re: 96spec 4x114 conversion (Dogginator)
u can find them . ap brakes makes them but its gonna be like 350-400 for the set of 4 . i rather do a 5 lug
nejra
Jul 16, 2009 07:37 PM
UNDERGROUNDAUTOSALON
Northeast (Sales)
Jul 22, 2006 05:14 AM
Mid-Atlantic (Sales)
Jul 22, 2006 05:13 AM
akteamster
Jul 25, 2005 09:34 AM
pedros94probegt
Nov 22, 2004 01:55 PM
