Valve Adjustment - Loud if too tight or too loose
Hey guys if I can here my valves make that click-click-click sound, are they too tight or too loose?
Daisy... Daisy...
Re: Valve Adjustment - Loud if too tight or too loose (AK77)
Ticking valves would be loose. Tight valves can cause compression loss and low RPM misfiring. The injectors also tick.
Re: Valve Adjustment - Loud if too tight or too loose (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Ticking valves would be loose. Tight valves can cause compression loss and low RPM misfiring. The injectors also tick.</TD></TR></TABLE>
If the valves are too tight it will loose compression and have low rpm misfire ? How tight are we talking here ? I have a rough idle after I adjusted my valves.
Re: Valve Adjustment - Loud if too tight or too loose (redDAinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg »</TD></TR><TR><TD CLASS="quote">
If the valves are too tight it will loose compression and have low rpm misfire ? How tight are we talking here ? I have a rough idle after I adjusted my valves.</TD></TR></TABLE>Tighter valves effectively give you a bigger cam.
