$5 boost controller question
Old Jul 23, 2002 | 09:58 AM
filetofit
Guest
Posts: n/a
Default $5 boost controller question
When using the el cheapo boost controller made from a ball bearing, spring, and brass fittings screwed together, do you need to poke a small hole in the line from the boost controller to the wastegate to relieve the pressure once the controller closes?
Old Jul 23, 2002 | 10:00 AM
DSF's Avatar
DSF
Default Re: $5 boost controller question (filetofit)
FYI: My slightly more than $5 Hallman BC does...
Old Jul 23, 2002 | 10:29 AM
CovertFI's Avatar
i have heard of boost spikes with this set up when the spring gets hot
just FYI
Old Jul 23, 2002 | 10:37 AM
filetofit
Guest
Posts: n/a
Default Re: $5 boost controller question (CovertFI)
I would think that as the spring gets hot the spring rate would go down and the wastegate would open sooner since the modulus of the spring steel decreases with increasing temperature.
Old Jul 23, 2002 | 10:42 AM
CovertFI's Avatar
well like i said that is what i heard. or maybe the spring rate (as you said) would go down so much that is would block the signal to the wg. not sure, but that is what i heard throught the grape vine
91integraLSVTEC
Oct 21, 2009 11:09 AM
*Boostwerks*
Apr 3, 2005 05:55 PM
LSEGHATCH
Dec 15, 2004 10:51 PM
BioXide02
Dec 22, 2003 11:41 PM
shingles
Jan 24, 2003 01:58 AM
