Clocking a turbo
Old Jul 22, 2002 | 08:52 PM
Ivan's Avatar
senior gold member
Default Clocking a turbo
I need to clock my t3 turbo and I've done the compressor side and need to do the exhaust side. It turns but brings the center piece with it and I don't want the center piece to move. Can anybody help. I've loosened the bolts but the center piece moves.
Old Jul 22, 2002 | 09:40 PM
ion_four's Avatar
Default Re: Clocking a turbo (Ivan)
you may have to pry off the exhaust housing to turn just the center. I had to use a bench-vise and a pry bard and about 10 minutes of working back and forth...
Old Jul 22, 2002 | 09:53 PM
Ivan's Avatar
senior gold member
Default Re: Clocking a turbo (ion_four)
Okay so I get the exhaust side off? Theres one bolt that won't come off cause the oil flange gets in the way.Do I just save that bolt till last and take it off while prying on the turbo?
Old Jul 23, 2002 | 09:59 PM
ion_four's Avatar
I had that same prob, you just have to work around it...get all the other ones off, then screw that bolt in as far as you can without it putting pressure on the seal, then try to pry it back and forth with a bar and get it apart just a enough to rotate it, then you can take that bolt off to take it apart, or just put the other ones on...when I put mine back together I put the metal "C's" on in such a way that the unaccessible bolts were on the open ends, so I could just take the "C's" off withouth removing those bolts...hope that made soem sense?
Old Jul 23, 2002 | 11:01 PM
Ivan's Avatar
senior gold member
okay I understand. I'll try tomorrow after work. Thanks for helping me out.
asianspeed
Dec 15, 2009 11:36 AM
drift2004
Oct 4, 2004 12:56 PM
slowdx
Sep 28, 2004 08:08 AM
