how hot does your water temp run when under a lot of boost
what kinda numbers you guys get and under what boost?i'm curious to know about your setups also,radiators slim fans etc?anyhelp would be great.
Re: how hot does your water temp run when under a lot of boost (hybridrex)
I stay at about 180 F, with stock radiator and one 11" slim fan. Without the fan the temp was the same, You only use the fans when the car is not moving or moving slow.
Re: how hot does your water temp run when under a lot of boost (civbeater90)
how do you check if your thermostat is broken? my stock temp guage goes a lil past half way with turbo... also where do you buy a lower temp thermostat? thanks
Re: how hot does your water temp run when under a lot of boost (Arturbo)
Hey Art kinda OT but did you have to trim the fan with your rev-hard mani? thanks man
Rob
Rob
Re: how hot does your water temp run when under a lot of boost (B20LS-T)
Wow you guys are runnign pretty cold. I'm runnign 207 under high boost, well then again its like 95 degrees here right now.
jdmspoonitr
10-13-2006 05:10 PM
turbotime
11-14-2005 12:45 PM
