correction: torque specs of Eagle rods for b18c1
The correct torque specs for Eagle rods on a B18C1 is 28 ft. lbs. using the ARP moly lube. You should use nothing but this lube for correct torque. Over-torquing the bolt will weaken it causing failure. Make sure it is ARP moly!!!!
dingusjt
Feb 6, 2015 08:59 AM
sscivicsi
Jun 29, 2008 05:43 PM
allanonjj
Jan 12, 2008 10:55 AM
