question about aem fpr
Old Jul 24, 2002 | 12:26 PM
JMinSi2000's Avatar
Default question about aem fpr
I just bought me an aem fpr and just started trying to install it. It didnt have an o-ring in the box and the stock one is just a little bit too big. Was it supposed to come with one and if so, what size so I can go buy me one?? I'm getting my car tuned in the morning so I have to get this installed tonight
Old Jul 24, 2002 | 12:28 PM
PM-Performance's Avatar
Default Re: question about aem fpr (JMinSi2000)
i think i had to use the stock one to tell you the truth, dont rememebr off hand though, it was soooo long ago
Old Jul 24, 2002 | 12:32 PM
JMinSi2000's Avatar
Default Re: question about aem fpr (itr206)
Well I cant get the stock one to fit in the groove.
Old Jul 24, 2002 | 12:58 PM
Firedrake's Avatar
It should have come with a new o-ring. The stock FPR o-ring is just slightly too large and will not fit.
Brian
Old Jul 24, 2002 | 01:25 PM
JMinSi2000's Avatar
Default Re: question about aem fpr (Firedrake)
I guess the shop I bought it at had it on display and didnt put the o-ring back in the box when i went to pick it up. I'm about to go get it from him...hopefully it'll fit and be the right one.
Old Jul 24, 2002 | 01:26 PM
JMinSi2000's Avatar
btw...how do you adjust it? do you unscrew the nut and then screw the rod in to increase fuel pressure or bring it out to increase fuel pressure?
Old Jul 24, 2002 | 01:28 PM
dustin's Avatar
I'm sure you could find one at autozone or pep boys
Old Jul 24, 2002 | 02:30 PM
speedymon's Avatar
Default Re: question about aem fpr (dustin)
yep, or NAPA.
Old Jul 24, 2002 | 03:34 PM
JMinSi2000's Avatar
Default Re: question about aem fpr (speedymon)
I got an o-ring at autoze...it didnt fit flush up against the outside groove but it seems to be working. Is the fuel pressure supposed to drop right back to zero when you shut off the car on these things? It stayed up there on the stock one.
Old Jul 24, 2002 | 03:41 PM
Marauder's Avatar
To increase fuel pressure, thighten the set screw, the opposite direction to decrease pressure.
Yes, the fuel system should hold pressure when the car is shut off, which makes restart easier since the system is pressurized already.
Old Jul 24, 2002 | 04:29 PM
JMinSi2000's Avatar
Default Re: question about aem fpr (Marauder)
I called AEM and they said it shouldn't hold fuel pressure when the car is shut off.
Old Jul 24, 2002 | 06:19 PM
JMinSi2000's Avatar
ttt....anybody that has had experience with this...does it hold pressure or not?
Old Jul 24, 2002 | 06:32 PM
TurboSedan's Avatar
New User
Mine does not hold pressure when the car is shut off.
Old Jul 24, 2002 | 06:56 PM
GruvyTune's Avatar
New User
i used a stock one cause my aem one tore. if you manipulate it just right it will seat in there, just be careful putting it on cause it will want to pop out when you turn it over. sealed just fine for me!
Old Jul 24, 2002 | 10:16 PM
Smashback's Avatar
No...if you turn the key to "on" you will hear the fuel pump priming the fuel system to compensate for the lack of pressure upon startup.
Old Jul 25, 2002 | 04:49 AM
symba's Avatar
Default Re: question about aem fpr (mplex2000)
Fuel pressure is not retained when the car is shut off. Once the key is turned to the "on" position, pressure is then restored for start up.
Old Jul 25, 2002 | 03:41 PM
bmm89's Avatar
Default Re: question about aem fpr (GruvyTune)
yes, i sprung a minor leak when i pinched my gasket... used a little silicone to "stick" the oring in place, then it won't move around when you tighten down
Leady
Jul 23, 2012 04:02 PM
DC2man
Mar 4, 2008 11:13 PM
85mm LS VTEC
Mar 25, 2004 10:52 AM
Mark
Sep 15, 2003 11:00 AM
ArchAngel Sabastian
Dec 8, 2002 06:20 AM
