race gas on turbo gsr?? (blue gas)
if i put that stuff in my car is it safe i have stck intjectors jus the inline fuel pump runnin frmo the fuel filter to the rail and i guess u mix it and how much hp will it give on a 8 psi boost level shftin at redline
Re: race gas on turbo gsr?? (turbogsr13z)
uhmm i really didnt understand that. not to be mean but what are you asking? how much more power you will make running a "race gas" ?
Rob
Rob
Re: race gas on turbo gsr?? (prophet)
Technically, you have the potential to make the most power using the lowest octane you're engine can handle without knocking (detonation). Octane is purely a measure of a fuel's resistance to knock.
if you have a cat, you wanna stay with unleaded fuel which the highest is 100 octane. the higher octane gas allows for more resistance against detonation which allows you to tune your engine more aggressively, which equals more power if done right.
Re: race gas on turbo gsr?? (csufweed)
http://blizzard.rwic.und.edu/~nordli.../gasoline.html
...lots 'o info
http://www.racegas.com/Racegas/fuelspecs/default.asp
...I fill up with GT when I head to the track in my beater.
...lots 'o info
Used2beAb16
39
04-08-2005 06:09 PM
