How does boost affect top speed?
Old Jul 25, 2002 | 04:55 PM
Trac226's Avatar
Default How does boost affect top speed?
What does boost pressure do at high speeds? Or is top speed only affected by gear ratios and drag limitations? At first, I would think that the extra power a turbo offers would give higher tops speeds... -just trying to learn more.
Old Jul 25, 2002 | 05:08 PM
SlowB16's Avatar
Default Re: How does boost affect top speed? (Trac226)
you go faster
Old Jul 25, 2002 | 06:23 PM
turbo craig's Avatar
Default Re: How does boost affect top speed? (SlowB16)
u can only max out at what ure gears will let u do on my ls i believe its like 140 something or it hits the limiter but if u raise the limiter u will go as fast as ure internals will let it
Old Jul 25, 2002 | 07:22 PM
Hammett's Avatar
mine topped out at 120.
Old Jul 25, 2002 | 08:44 PM
*Boostwerks*'s Avatar
Default Re: How does boost affect top speed? (Hammett)
I was able to get to 125 (still had about 1000 RPM left till redline)
In about 11 seconds....It was fast!
Old Jul 25, 2002 | 08:50 PM
Ri5e's Avatar
Default Re: How does boost affect top speed? (Bryson)
Boost doesn't affect top speed. Gearing affects top speed. Boost just lets you hit top speed faster
[Modified by BG Boost, 5:51 AM 7/26/2002]
Old Jul 25, 2002 | 08:53 PM
Default Re: How does boost affect top speed? (BG Boost)
well actually it does....
Boost (In other words "power")....will allow you to over come more of the resistances in Air/tire/berrings of the car at high speeds...thus being able to get to higher top speeds.
I would like to see a stock CRX HF get to 120!!!!!
You are correct though of course, as gearing will play the BIGGEST role in the top speed of the car.
Old Jul 25, 2002 | 09:06 PM
csufweed's Avatar
shoot... only 125?!?! i've hit 141mph with plenty to go... and I got less power than all of ya'll!
Old Jul 25, 2002 | 09:43 PM
echo999's Avatar
New User
In other words.. you may have long enough gears to hit 250mph, but you'll
never hit 250mph if you don't have enough horsepower to overcome all the
forces against the car.
With the amount of HP we get added with our turbos, we can easily top out the gears in our cars.
Old Jul 25, 2002 | 10:30 PM
Trac226's Avatar
Default Re: How does boost affect top speed? (echo999)
And that's where top end, high speeds, and poor tuning kill motors right?
Old Jul 25, 2002 | 10:52 PM
97SprchrgdCIVIC's Avatar
Default Re: How does boost affect top speed? (csufweed)
Hey there I gotta JRSC 97 civic ex 1.6L vtec the fastest I've had it up to is about 135mph so far I always seem to get some a-hole in front of me drivin slow or maybe I'm drivin too fast either way u get my point That was before I put the SC on and I havent got a chance yet to try and get above that since I've put it on, anyways I believe the speed limiter in my vehicle is 134mp so maybe I wasnt goin 135 who knows since I've put the SC on i've noticed I run alot warmer especially when Im rompin on it but thats expected I guess, more air, more gas, equals more heat!!!!!!!! RACE ON!!!!!!
chippinpressure
Nov 15, 2010 11:18 AM
b20beast83
Jul 30, 2009 06:26 PM
type B16
Oct 30, 2006 05:32 PM
Kack
Aug 25, 2003 11:25 PM
sutrusu
Oct 17, 2002 12:33 PM
