Fuel Pressure help!!
Old Jul 23, 2002 | 11:06 PM
B20-T's Avatar
Default Fuel Pressure help!!
I just install my turbo today..with the fmu,rc370cc,fuel pump.i tried the vortech fpr , but now i got the stock one on..I get a reading of 0psi on my guage.before the guage work but now it just sits at 0 or it barely move up to 15psi when i step on it..I took it for a test run everything okay no bog or no stutter at all.but the psi sit very low..can someone please help with this..
Old Jul 23, 2002 | 11:08 PM
VaporTrail's Avatar
New User
Default Re: Fuel Pressure help!! (B20TURB0)
are you running an inline pump? Where is the gauge mounted? If the gauge is mounted on the fuel filter, like the B&M is, and you are running an inline pump, you won't see any fuel pressure there.
Old Jul 23, 2002 | 11:14 PM
B20-T's Avatar
Default Re: Fuel Pressure help!! (VaporTrail)
yeah i am running a inline pump..its mountin right there by the bov on the wheel wall just right there by the battery..and the guage is mounted on the fuel filter.
Old Jul 23, 2002 | 11:24 PM
VaporTrail's Avatar
New User
then you have no problems
Old Jul 23, 2002 | 11:25 PM
Dutchie's Avatar
So it is connected after the filter than. Like Vapor said, that will **** up the reading off the guage. You will have to relocate it to the fuel rail.
Old Jul 23, 2002 | 11:31 PM
B20-T's Avatar
Default Re: Fuel Pressure help!! (Dutchie)
oh okay thankx guys..one more question what size fitting do u use for the oil feed line>?
Old Jul 25, 2002 | 08:12 PM
forcedaccord95's Avatar
I just did a turbo on a 95 honda accord and my guage was reading 0 too, I have an external fuel pump, but the guage is before it on the filter, do I need to do the same and move it up to the rail?
Old Jul 26, 2002 | 07:24 AM
Dutchie's Avatar
Default Re: Fuel Pressure help!! (forcedaccord95)
If by before the pump, you mean closer to the gas tank then yes. If not, the guage is probably broken.
Old Jul 26, 2002 | 07:28 AM
CovertFI's Avatar
i have been here since january i have have seen about 5 post like this. you think they would put some kind of FAQ about this in the fuel pump documentation. But then again i dont read instructions untill i get stumped or i have to crap. my 2 cents
Old Jul 26, 2002 | 07:32 AM
B20T's Avatar
put the pump before the gauge and it will be fine
Old Jul 26, 2002 | 09:40 AM
b18b98's Avatar
1/8 npt for the back of the block. For my turbo its a 1/4 but others have 1/8.
Element3488
12
Nov 19, 2012 08:53 AM
sway892
Jun 4, 2004 04:46 PM
DRIVENRacing
May 22, 2004 10:41 PM
DoriDoriboii
Apr 1, 2003 11:08 AM
ragejed
Jul 23, 2002 09:57 AM
