Help: Problem Starting Car with Hondata
I have a '99 Civic Si with Greddy Turbo, 450cc injectors etc and I've recently installed a Hondata Stage 2B with datalogging. I'm having a problem everytime I start my car. I has to turn over several times and I have to blip the throttle a bit to get it to start. I adjusted the TPS voltage to .45V last night, with the car not running, hoping that would fix it but it did not. Any help would greatly be appreciated?
[Modified by ElectronMan, 11:57 PM 7/24/2002]
Gude, aren't you running with Hondata? What is your Hondata setup? which ECU do you have and did you find it all you had hoped for? I'm trying to decide between Hondata and AEM EMS.
im not running the hondata yet, i will be in the next few weeks though. im running the p75 integra LS ecu, ill let you know how everything runs. i chose hondata because of the dyno shop im going to have tuning it down to a science, next summer i probably will run the AEM EMS once it is more familiar to tuners and has all of the little kinks worked out.
