....................Supra Fuel pump .................
Old Jul 25, 2002 | 03:48 PM
CRVRX's Avatar
Default ....................Supra Fuel pump .................
Does anyone have pics? will it fit in a Honda tank?
Thanks, ( I did the seach )
Old Jul 25, 2002 | 04:12 PM
Jared's Avatar
Default Re: ....................Supra Fuel pump ................. (CRVRX)
will fit, almost the same dimensions.
Old Jul 25, 2002 | 07:09 PM
CRVRX's Avatar
Default Re: ....................Supra Fuel pump ................. (Jared)
Cool Thanks! , Any ideas how much they are ?
Old Jul 25, 2002 | 07:59 PM
SiRkid's Avatar
125 used
Old Jul 25, 2002 | 08:12 PM
littlebluecrx's Avatar
I have a brand new one for 150.00, Jason
Old Jul 25, 2002 | 08:39 PM
*Boostwerks*'s Avatar
Default Re: ....................Supra Fuel pump ................. (littlebluecrx)
Why not use a Walbro 255?....not disagreeing...just wondering why?
Is the Supra pump BETTER then the walbro?
Old Jul 25, 2002 | 08:44 PM
wickedxboi's Avatar
Default Re: ....................Supra Fuel pump ................. (Bryson)
is it inline or intank?
Old Jul 25, 2002 | 08:48 PM
Default Re: ....................Supra Fuel pump ................. (wickedxboi)
In tank.
Old Jul 25, 2002 | 08:52 PM
Xerxes's Avatar
New User
supra pump is quiet as stock!
Old Jul 25, 2002 | 08:57 PM
Default Re: ....................Supra Fuel pump ................. (Xerxes)
what is the flow rate of it though?....
If it's quieter but flows as much as the walbro, I now know what pump I will be using!!!!!!!
Old Jul 26, 2002 | 02:37 PM
TriK's Avatar
quiet as stock...
reliability of toyota (nipodenso)...
and a good price.. (cost)
and 255 lph too
voila
Old Jul 26, 2002 | 02:55 PM
WA  DA  TA's Avatar
Do you still have the pump? And the pickup screen (not a big deal if you do not)?
If you have it can I pick it up this sunday at the race?
thanks!
email me involvedtiger@yahoo.com
Old Jul 26, 2002 | 09:32 PM
TriK's Avatar
Default Re: ....................Supra Fuel pump ................. (gsx4R1)
keep stock strainer..(pickup screen)
Old Jul 26, 2002 | 10:11 PM
D-Man's Avatar
Default Re: ....................Supra Fuel pump ................. (TriK)
I was gonna go with a Supra pump,but there's one big problem with it(at least for me)..when that pump was originally installed in the TT Supra it does not see 12 Volts all the time,only when the computer see a need for extra fuel does it switch it to 12V otherwise its running at 6 volts..so it may overheat running a constant 12V..I went with a 375lph Bosch Pump instead of the 260lph Supra Pump.
Old Jul 26, 2002 | 10:37 PM
boostinb18's Avatar
Default Re: ....................Supra Fuel pump ................. (D-Man)
has anyone else heard of this problem???
Old Jul 26, 2002 | 11:00 PM
D-Man's Avatar
Default Re: ....................Supra Fuel pump ................. (boostinb18)
i doubt it,unless there is someone in here that really knows toyota electronics inside and out,you need to find a supra forum on the web somewhere and ask over there.
Old Jul 26, 2002 | 11:21 PM
SiRkid's Avatar
hmm..bosch...do you have any more specs on that pump?
Old Jul 26, 2002 | 11:32 PM
D-Man's Avatar
Default Re: ....................Supra Fuel pump ................. (SiRkid)
i got it from Payn tech,im mounting it externally,it has an 14mm 10AN intake and an 8AN,i think around 12mm out. but with some work,it can be installed intank,the oldone sells a smaller version that is shortened that fits in better but its also pumps much less LPH than the one i got..ill get the Bosch Part # off the Pump tomorrow if you want.
Old Jul 27, 2002 | 07:11 AM
SiRkid's Avatar
thanks, do you have more info on it.
I just bought this pump this past week. I knew it was a good pump and a good deal came up so i bought it but i really have no clue on the specs but thats for some info.
Old Jul 27, 2002 | 08:15 AM
turbo Si's Avatar
I have the 97' TT Supra pump on my car. I can't remember what site someone from this board referred me to but it said
12volts = 260lph
14 volts = 290lph
16 volts = 320lph
18 volts = 350lph
It said the pump is good up to 18 volts! I would'nt doubt what D-MAN said about it not reading 12 volts all the time although I think you can put a relay and it would be fine. I have no complaints about the pump. It's a tight fit though. I believe the pumps now come with a non - flexible filter rather than the sock type that Honda has. I was lucky they had one sitting around because you will need the sock type to sit on the bottom of the tray. If you have the other filter, don't even bother because it will not fit, and if you do get it to fit the filter will be facing upward rather than sitting at the bottom of the tray. Other than that the bracket will have to be modified a bit to mount the pump. The bracket is in the shape of an L. Cut the bottom portion of the bracket, where the pumps sits, off. This is because the Supra pump is too long. We then use a hose clamp to hold the pump onto the bracket.
Good luck!
Old Jul 27, 2002 | 09:35 AM
wickedxboi's Avatar
Default Re: ....................Supra Fuel pump ................. (turbo Si)
how much does a new supra tt pump run for?
Old Jul 27, 2002 | 09:37 AM
^^^^^^^^Look up...^^^^^^^^^
Old Jul 27, 2002 | 09:46 AM
93LSivic's Avatar
This might help someone............somehow
http://www.titanmotorsports.com/titmotsuptur.html
Old Jul 27, 2002 | 10:21 AM
Ubermensch's Avatar
Here's some info for you:
[Modified by Ubermensch, 11:21 AM 7/27/2002]
Old Jul 27, 2002 | 06:38 PM
D-Man's Avatar
12volts = 260lph
14 volts = 290lph
16 volts = 320lph
18 volts = 350lph
The walbro or just about any pump can be overdriven 18+ volts to pump up the volume..kenne bell boost-a-pump and i believe MSD has control boxes to do just that.
