Boost gauge line
Old Jul 23, 2002 | 08:35 AM
Pengo's Avatar
Default Boost gauge line
for those running autometer boost gauges with the nylon tubing it comes with, how did u hook up the nylon tubing to your vacuum source? is there a location that the brass fittings the gauge came with will fit on? or did u use some other fittings? thanks
-alan
Old Jul 23, 2002 | 08:43 AM
johnmay19's Avatar
Default Re: Boost gauge line (Pengo)
I just tee'd it in with a vac. line.
Old Jul 23, 2002 | 08:51 AM
udctown's Avatar
New User
i went to NAPA and got the necessary fittings to make a tee. it's not too hard. just take the brass fitting that came with the guage and compare.
Old Jul 23, 2002 | 09:13 AM
93LSivic's Avatar
I lucked out and found a T that the nylon line would pressure fit into.
If you cant find anything I would suggest a rubber vacuum line going from the gauge to the manifold.
Old Jul 23, 2002 | 09:17 AM
VaporTrail's Avatar
New User
I prefer to run a hard line, such as copper tubing.
Old Jul 23, 2002 | 09:35 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: Boost gauge line (93LSivic)
That's what I did. Much easier that way.
blackccoupe
May 18, 2004 07:26 PM
Westsideboy
Apr 19, 2003 05:21 PM
B18EG6
Aug 7, 2002 12:31 PM
greyzone
Nov 11, 2001 05:06 PM
falcongsr
Jul 3, 2001 03:14 PM
