Spark plug help
Old Jul 22, 2002 | 09:57 PM
B20-T's Avatar
Default Spark plug help
I have a b20vtec turbo..I got some ngk-brk7e spark plugs what should i gap these spark plugs at?My ignition setup, i have a msd 6al w/blaster coil and managcore 8.5mm wires..
Old Jul 22, 2002 | 10:10 PM
Dutchie's Avatar
Default Re: Spark plug help (B20TURB0)
.36 should be fine. How much boost are you running.
Old Jul 22, 2002 | 10:11 PM
B20-T's Avatar
Default Re: Spark plug help (Dutchie)
about 9psi
Old Jul 22, 2002 | 10:54 PM
Dutchie's Avatar
I would think .36 should work for you. If you have it on a dyno and your curve isn't smooth in the top end then you probably have too much gap. I have been running .40 on pfr7g-11's for 2 years without a problem. That is only at 5 psi though. The more gap you can run safely, the better.
Old Jul 23, 2002 | 09:40 AM
earl's Avatar
Just in case it a newb, it's not .36" but .036" plug gap. You never know how literally some people take a post
Old Jul 23, 2002 | 10:00 AM
Dutchie's Avatar
Default Re: Spark plug help (earl)
Lol, I never remember the 0 .
turbo Si
Apr 24, 2003 08:34 PM
advan7
Apr 13, 2002 02:31 AM
Type R 702
Mar 7, 2002 12:01 PM
JDM R98
Aug 12, 2001 10:33 PM
