Loud Squeaking?
Old Mar 13, 2002 | 03:54 AM
Adampops's Avatar
Default Loud Squeaking?
Just recently i noticed that every time i go over a large bump or a change in the road survace my car lets out a quick but loud squeak comming from the passenger side front wheel. I have no idea what it could be? Do you guys have any ideas? Thanks
Old Mar 13, 2002 | 08:30 AM
Red98GSR's Avatar
New User
Default Re: Loud Squeaking? (Adampops)
quick + loud = probably something in the shock assembly.
Old Mar 13, 2002 | 09:47 AM
Fooser's Avatar
Default Re: Loud Squeaking? (Red98GSR)
I remember my ABS system came loose on a bolt that held it down. Check that just press it and see if it causes a noise. It might be loose.
Old Mar 13, 2002 | 02:57 PM
gsr stuie's Avatar
Default Re: Loud Squeaking? (Fooser)
wheel rubbin?
Old Mar 13, 2002 | 08:11 PM
sLo B18b's Avatar
New User
Default Re: Loud Squeaking? (gsr stuie)
try bouncing the front of ur car up and down.....it might be ur springs. mine squeak and i hate it with a passion. if im not mistaken, IF it is the springs, its probably the dead coils rubbing against each other. i read somewhere that it can be fixed with those plastic wire wraps found at radio shack. ur suppose to wrap them around ever other coil.. hth
Old Mar 14, 2002 | 02:29 AM
Adampops's Avatar
Default Re: Loud Squeaking? (sLo B18b)
It's definaltly not ABS since my car doesnt have it. And im pretty sure its not tire rub, cuz that has happened before and its not the same sound. Im gonna go check out my suspension. Thanks a lot for all your help.
Mountshy
Honda Civic (2001 - 2005)
Sep 18, 2010 04:47 AM
JDMoneDC5
Apr 22, 2009 04:15 AM
killyourscene
Honda Civic (2006 - 2015)
11
Jun 30, 2007 11:05 AM
tofuR
Jul 13, 2003 01:43 PM
