Bad engine Smells~~ please help
Old Mar 15, 2002 | 08:29 PM
PaChiLa Leader's Avatar
Default Bad engine Smells~~ please help
i reved redline from 1 to 4th gear yesterday
and now my teg has bad ****ed up smells coming out from the vents........
i don't think i bent the valve coz car idles fine
Seems the smells only came out whenever i turn the on the AC or heater
What should i Do?
i have an LS 5 speed but running with stock Auto ECU
could that be the problem for not reving too high?
please help
Old Mar 15, 2002 | 08:47 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Bad engine Smells~~ please help (PaChiLa Leader)
Could be your clutch....you ever smell burnt clutch before?
The odor will linger a little bit. If you know that it's not clutch, then I'm not sure.
Old Mar 15, 2002 | 09:59 PM
Mr. Thunderlips's Avatar
you should check for a dead rat under your hood...im not joking...i was at my buddies house the other day, he popped his hood, and a huge *** rat was chillin by the firewall...it started crawling around, so he shot it in the head with a BB gun...i know this story sounds terriblt rediculous...but i swear its true...
Old Mar 15, 2002 | 10:24 PM
01-1293's Avatar
Default Re: Bad engine Smells~~ please help (ThunderLipps)
Ya..........very true........some kind of woodlen creaturechewed a hole in my fuel line .............. the next morning i tried to start the R and gas started pouring everywhere.....sorry kinda OT
Old Mar 15, 2002 | 10:49 PM
mickey513's Avatar
I have the same problem with my gsr but I never redline it or anything. Seems to come on only when I turn on the AC and sometimes heat..........
Old Mar 16, 2002 | 03:26 AM
Thanks for all the inputs guys
I only have my new clutch installed and drove 1500 miles or so
what would i do to damage or burn the clutch? and what kinda smells is that?
I am should theres no dead rats under my hood
hahahha nice one though
But you know what's funny, i think the smells might came from the tires
coz when i redline it and shifting sometimes the wheel spins and stuff....
Old Mar 16, 2002 | 03:32 AM
radiator?
Oh yeah i was thinking it might have something to do with the radiator too.
ok here's the thing
i did auto to manual conversion few weeks ago
after the swap i found out there were some kinda oil leaking so i went back and double check with the shop right.
they told me that was the cooler oil for auto's, Manual doesn't need it...... so here comes the question....
Doesn't Standard need some kinda fluid to cool down...
and i also found out that the fan doesn't run these days...
any ideas?
Old Mar 16, 2002 | 08:21 AM
GSRaCeRbOI's Avatar
can you elaborate on the smell? burnt clutch smells like burnt brake.. you kno.. that friction material smell... is it just an odor? I remember when i smoked up my stock tires (i wanted to wear them out so i could get rims)... i had smoke pouring/billowing out of the wheel wells and smoke (like ciggarette smoke/gassy) into my air vents.. hahah
Old Mar 16, 2002 | 12:49 PM
shamoo's Avatar
Well, I'd say it's probably your clutch. You know what burnt rubber smells like right?
Clutch smells pretty nasty. If you shift hard and fast, you might get a lingering odor. It's nuthing to worry about. That's why people tell you, if you shift hard and fast like that, it's more wear on your clutch.
Old Mar 16, 2002 | 03:09 PM
Default Re: Bad engine Smells~~ please help (shamoo)
GSRaCeRbOI
Thank you very much
[Modified by PaChiLa Leader, 4:10 PM 3/16/2002]
rc2904
39
May 9, 2016 07:11 AM
LsTegDriver
Aug 28, 2008 07:13 PM
E36 Guy
12
Dec 13, 2005 11:42 PM
b18CivicEx
Jan 19, 2005 01:15 PM
