ls/vtec question
Old Mar 17, 2002 | 08:26 AM
b18hatch's Avatar
New User
Default ls/vtec question
IM sure this question has been asked but i could not find and answer from using the search. So IM planing on picking up a DA integra. Old right? hahah. Okay well the one im looking at is a 91 so it ahs the b18b the 92-93 have the b18b1. so im trying to figure out how i would put a vtec head on it. I thinking most likely about using a 1st gen b16 head head beacsue of avabilit but im afrade i might run in to some ussues about the no-obd. A b17 head would be nice but i could never find one. or whould it be better to use obd-1 gsr head or should i just convert it to obd-2.
all right so in thearoy i got my head, new harness or i could wire it in. and a new ecu, would i still ahve to tap the block similar to b20/ correct? also since this motor has close to 100 miles on it shoudl i just use a new block?
thanks guys
Old Mar 17, 2002 | 09:59 AM
sleeper4dr's Avatar
Default Re: ls/vtec question (b18hatch)
FYI
90-93 integra LS is the B18a
94+ Integra LS is the B18b
i think you meant to say the block has 100K miles correct? if thats the case then at the very least you should replace the main and rod bearings.
youngyankee585
Sep 11, 2013 05:39 AM
2ndchirp
Mar 10, 2009 06:36 PM
Ignitecivic
Jun 11, 2003 08:56 AM
Triumphant
Jun 3, 2003 10:34 PM
black-hatch
Feb 21, 2003 09:09 PM
