Question on Chipped OBD 1 p72
If i get a chipped OBD 1 ecu, would it run good with my gsr manifold? The reason i ask is because i don't have enough money to get a obd1 harness, obd1 chipped ecu, and skunk2 intake manifold.
I have heard that p28 users use only a single runner intake manifold. But since the p72 is made for the GSR, would it still open up my secondaries even though its chipped?
Re: Question on Chipped OBD 1 p72 (StinkyTofu)
if u are gettin a custom chip u can tell the person to disable the double butterfly and make it a single on da p72
Re: Question on Chipped OBD 1 p72 (GSRfoedoe)
Yes the chipped obd1 p72 ecu will work fine. When people go to the skunk manifold, they generally run a chipped obd1 p28 ecu for the single runner.
yes the p72 will still operate your butterflies after being chipped. if your going to get the skunk mani, then i'd just get the p28
Re: Question on Chipped OBD 1 p72 (MaliceGSR)
Sweet, i think i'm just going to get the p72 for now. I have no money for a skunk2 intake manifold at the moment. Any advantages of running p28 as opposed to p72 other than the fact that there are more chips offered for the p28? I plan on getting a hondata some day, so i think a chip would be pointless. Just has to be obd1 right?
New User
Re: Question on Chipped OBD 1 p72 (dubster99)
what happens if you run a skunk2 manifold with a p72 ecu and with no chips? I've got a similar setup, and it works great. It did'nt seem to be leaning out or anything.
Guest
Posts: n/a
Re: Question on Chipped OBD 1 p72 (teger)
I've had a lot of chips, and I'm starting to chip ECU's now. The main thing I've noticed is that most GSR chips have the information for the dual runner built into it.
