hoses sizes
Old Apr 20, 2003 | 10:15 PM
turbohondask's Avatar
Default hoses sizes
Does anyone know the size for the following hose ( the inner diameter if possible)
water pipe to the IAC controller
pvc vavle to intake manifold
charcoal canister to the vavle thing on top of the manifold
this is off a 96 integra ls
does anyone know where the charcoal canister hose go to, beside the one that goes to the fuel tank
thanks
Old Apr 21, 2003 | 07:57 AM
IN VTEC's Avatar
Default Re: hoses sizes (turbohondask)
Probably 1/4" ID for the larger hoses (eg: PCV valve) and 3/16" or 1/8" for the smaller ones.
For the EVAP system, the big hose on the top of the charcoal can goes into the throttle body nipple. One of the small ones goes aft to the tank for the 2-way valve, the other small one goes to the EVAP solenoid by the ****.
The other end of the EVAP solenoid valve gets run to a nipple on the IM for engine vacuum.
This is for a OBD-I B18B1, but I don't think they changed much except for the placement of the EVAP purge solenoid valve.
Old Apr 21, 2003 | 08:05 AM
IN VTEC's Avatar
Default Re: hoses sizes (IN VTEC)
Forgot the flash, but you can figure it out just from this.
Old Apr 21, 2003 | 09:53 AM
thanks for the info
Enta
Jan 29, 2007 03:51 AM
vietnamese0utlawz
May 19, 2006 09:46 PM
Teknic73
Mar 31, 2006 04:45 AM
JerseySiPOS
12
May 16, 2004 10:40 AM
citanest
Jan 14, 2002 10:26 PM
