Type R sway bar question
Old 04-19-2003, 05:05 PM
grngsr01's Avatar
Default Type R sway bar question
I m planning on installing a bar. I thought I heard somewhere that you can destroy the rear subframe of the car. I know about the mounting kit from BSQ. I did notice that stock mounts are no longer used because of the larger bar. It is save to use the top original one and the ABS mounting hole like said on BSQ's website.
Old 04-19-2003, 06:07 PM
Tweakmeister's Avatar
Default Re: Type R sway bar question (grngsr01)
BSQ's setup is sound. you will have to grind the ABS brackets or just remove them.
Old 04-19-2003, 08:12 PM
Hairy Gorilla's Avatar
Default Re: Type R sway bar question (Tweakmeister)
I've installed the bsq setup on 2 different gsr's now and neither have I had to remove the abs brackets. All you have to do is enlarge that one hole on each side. Not a problem and won't hurt anything.
Old 04-20-2003, 10:26 AM
basmasta7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">BSQ's setup is sound. you will have to grind the ABS brackets or just remove them.</TD></TR></TABLE>
i never grinded the ABS brackets. i just drilled through the hole in the bracket as well as the subframe. works pefectly
Old 04-20-2003, 10:49 AM
PaChiLa Leader's Avatar
Default Re: Type R sway bar question (basmasta7)
yeah BSQ kit will fit you just fine
Old 04-20-2003, 01:41 PM
BerlinaAP2's Avatar
Default Re: Type R sway bar question (PaChiLa Leader)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PaChiLa Leader &raquo;</TD></TR><TR><TD CLASS="quote">yeah BSQ kit will fit you just fine</TD></TR></TABLE>
Old 04-20-2003, 02:56 PM
ebelp's Avatar
Default Re: Type R sway bar question (ApexiSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApexiSi &raquo;</TD></TR><TR><TD CLASS="quote">yeah BSQ kit will fit you just fine</TD></TR></TABLE>
Old 04-21-2003, 10:26 PM
NA gs-R 05 C
Guest
Posts: n/a
you'll be just fine with the bsq kit unless u want bling then go with the beaks, but both r good.
Old 04-21-2003, 11:37 PM
Audio28's Avatar
Default Re: Type R sway bar question (NA gs-R 05 C)
y do you need the bsq kit for? can you install the bar w/o the kit? also what does the bsq kit consist of? I have my bar laying here, but i don't want to waste money on something i don't need.
Old 04-22-2003, 02:09 AM
tC_Dragon's Avatar
Default Re: Type R sway bar question (Audio28)
get the bsq kit.... last thing you want is to tear out ur subframe cuz it was too weak to support the flexing of the sway bar. only 20 bucks or so...
Old 04-22-2003, 08:07 AM
New User
WiggiE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Audio28 &raquo;</TD></TR><TR><TD CLASS="quote">y do you need the bsq kit for? can you install the bar w/o the kit? also what does the bsq kit consist of? I have my bar laying here, but i don't want to waste money on something i don't need.</TD></TR></TABLE>
BSQ Kit
Installation instructions for BSQ Kit and sway bar
If you don't use his kit, or some other sort of subframe reinforcement, you will damage the subframe.
Old 04-22-2003, 09:35 PM
Audio28's Avatar
Default Re: Type R sway bar question (WiggiE)
thanks
neof69
02-07-2008 08:33 PM
MAD GSR
Suspension & Brakes
05-15-2005 03:54 PM
Try2Live4God
04-15-2005 03:46 PM
GSRrR
06-28-2003 10:26 PM
skunkintegra
05-02-2003 03:31 PM
Quick Reply: Type R sway bar question
