crank angle sensor?
Old Apr 19, 2003 | 01:59 PM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Default crank angle sensor?
where the hell is the crank angle sensor on a B18a LS motor...
Old Apr 19, 2003 | 04:18 PM
Danger's Avatar
Default Re: crank angle sensor? (Nvious R)
i dont think the older motors have that sensor .
Old Apr 19, 2003 | 04:27 PM
Full Race EG's Avatar
Default Re: crank angle sensor? (JonnyDanger)
Nope. They do not have 1. Only newer hondas do.
Old Apr 19, 2003 | 04:35 PM
mr.beeks's Avatar
crank angle sensor?
there are three sensors located inside the distributor
could name two for now
1 tdc (top dead center)
2 (piston location sensor)
3???
Old Apr 19, 2003 | 05:04 PM
Danger's Avatar
Default Re: crank angle sensor? (FRANCISCO FLORES)
isnt the crank angle sensor in the oil pump area , if not on the oil pump itself ?
Old Apr 19, 2003 | 06:39 PM
kombo83's Avatar
this is not a good thing someone help me plz.why did we run a diagnostic on my car and crank angle sensor showed up.im using a 92 distributor but i swaped a b18b.i thought the crank angle sensor was in the distributor.cause i got that and tdc sensor.
Old Apr 19, 2003 | 06:47 PM
MugenGTR's Avatar
older motor do have them, obd1 motors do at least, it's in the distributors, i don't think there's anyway to change out, u need to get a new distributor if it's faulty.
Old Apr 19, 2003 | 06:50 PM
mr.beeks's Avatar
tdc top dead center
ckp crank shaft positioning sensor
cyp cylinder position sensor
all of them located inside distributor
just confirmed
what year engine you have
and what distributor you are using
Old Apr 19, 2003 | 06:57 PM
kombo83's Avatar
im using a distributor from my old block which was bad already just ordered a new one.i got a 94 b18b in my 92 ls.not sure if the mechanic was reading it for the 92 or 94.car is running rich as hell and im getting spark at the wrong time.its not in synch.just have this popping exhaust at idle.
Old Apr 19, 2003 | 06:58 PM
kombo83's Avatar
Default Re: crank angle sensor? (kombo83)
oh yeah the idle just bounces up and down and almost stalls out unless i give it some gas or raise the idle to 2500.
Old Apr 19, 2003 | 08:24 PM
3rdGteg's Avatar
what code exactly did u pull? if it's a cel code 4, then it's ur CKP(crankshaft position sensor) inside the distributor. If it's the code 54 for the CKF(crankshaft speed fluctuation sensor/known to some as the crank angle sensor) it's on your oil pump but only exist on obd2 engines '96-up (u shouldn't have one). btw, TDC and CYP are a couple more sensors also inside of the distributor.
Old Oct 28, 2003 | 06:27 PM
michaelpr's Avatar
New User
Default Re: crank angle sensor? (3rdGteg)
Did the new distributor solve your problem?
Ash J. Williams
Engine Management and Tuning
Aug 8, 2012 09:57 PM
SwappedLSHatch
Apr 13, 2006 01:33 PM
The Jamaican
Apr 14, 2003 07:54 PM
prjctCIVIC
Aug 26, 2002 08:34 PM
